Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Wont stop filling
Have checked for obstruction in tube, seems to be no obstruction machine just keeps filling up. it is a fisher & paykel intuitive about 10 yeard old.
  • richard_anne Apr 19, 2009
    not sure what you mean by timer? i thought the water worked on a pressure switch,which detects the water level , the water stops when the machince is turned off so inlet valves ok.
  • Anonymous Mar 16, 2014
    Machine is not filling up water is just trickling into machine. Have checked hoses for kinks and taps are on
    Problem Solver:
  • 17 Answers
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Posted on Apr 19, 2009
  • 221 Answers
The water inlet valve may be stuck open, it's usually located at the back of the washer, the cold and hot water hose's connect directly to the water inlet valve, if water go'es in to the washer when it's turned off the valve is defective, if it does'nt leave the fill cycle after starting the timer may be bad.
Posted on Apr 18, 2009
Code 40 on my eco intuitive what does it mean
40. (00101000) Bowl Dis-engage Fault
While carrying out a bowl check, the Motor Control Module has found that the bowl is not engaged even though the pressure sensor indicates that the bowl is empty.
The Motor Control Module continues to check for 2 minutes,
after which time it displays this fault.
The first two areas to check are the clutch and the pressure tube.
If these two appear correct, then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing the clutch from re-engaging.
Excessive suds can stop the bowl rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
442 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
