Outlook exspress up dated and I can not sent e-mails, i recieve ok
  • 3 more comments
  • anthonyvolen Apr 18, 2009
    error message (0x80042109) 'outlook cannot conect to your outgoing (smtp) e-mail server
  • anthonyvolen Apr 19, 2009
    will not let me change from 25 to 26 as it tells me this can not be done as its the same users name
    OFFICE 2007, I have tried all the above and deleted user and create a new user, changed 25 to 26 and back again. Windows Vista Home on pc
    my pop setting is pop.mail@yahoo.co.uk
    my stmp setting is stmp.mail@yahoo.co.uk
    my other setting is now set at 26 and am not getting an error message but still not able to send
  • anthonyvolen Apr 20, 2009
    THANKYOU for ALL your help. I can now send e-mail's again
    Problem Solver:
  • 5 Answers
You will need to make sure that your SMTP settings are correct. If you're using a private email server or an ISP mail server, you will need the correct settings.
Also, in some cases the SMTP server will require user authentication.
I'm not 100% where to find this in Outlook Express, but in Outlook 2007 you go to Tools > Account Settings > Select your account > Click Change... and from there you should be able to see a few settings.
Look for a checkbox that says:
My outgoing (SMTP) server requires user authentication,
Click that checkbox if it's not already selected. Chose option #2:
Log on using:
Enter your username and password in the appropriate fields. Save your settings and then try.
Let me know if this helps at all.
Given the fact that you said you can receive messages but cannot send, I know 100% that it's an SMTP issue which is fixable.
Posted on Apr 18, 2009
  • 3 more comments
  • mat4 Apr 18, 2009
    What's your current incoming mail server (POP) and outgoing mail server (SMTP) settings?
    Example:
    Incoming: mail.yourdomain.com
    Outgoing: mail.yourdomain.com
    Plaese include the port settings as well, if you could.
  • mat4 Apr 18, 2009
    One thing you could try:
    If you check your Advanced connection settings, you should see an Outgoing (SMTP) port. In most cases it's 25 or 26. If it's not change to 25. If 25 does not work, try 26.
    This is one of the most common problems when connecting to remote SMTP servers.
    So, again, if the port reads 25, change it to 26. If it's on 26, change it 25. If it's not set to either 25 or 26, try changing it to either 25 or 26.
  • mat4 Apr 19, 2009
    What version of outlook express are you using?
    Also, is it for home use or at an office? If you're using it with an Exchange server that would be a bit different.
    Example:
  • mat4 Apr 19, 2009
    Example:
  • mat4 Apr 19, 2009
    1. In the Outlook main menu, click Tools, then Account Settings. This opens the Account Settings dialog box.
    2. On the E-mail tab, click New. This launches the Add New E-mail Account wizard.
    3. On the Choose E-mail Service screen, select Microsoft Exchange, POP3, IMAP, or HTTP, then click Next.
    4. On the Auto Account Setup screen, set the Manually configure server settings of additional server types checkbox and click Next.
    5. On the Choose E-mail Service screen, select Internet E-mail, then click Next.
    6. Enter your name as you want it to appear in messages in the Your Name field.
    7. Enter
      your full Mail Plus address (user@yahoo.com) or Business Mail address
      (for example, user@yourdomain.com) in the E-mail Address field.
    8. Select POP3 in the Account Type list.
    9. For
      a Mail Plus account, enter "pop.mail.yahoo.com" in the Incoming mail
      server (POP3) field and "smtp.mail.yahoo.com" in the Outgoing mail
      server (SMTP) field.
    10. For a Business Mail account, enter
      "pop.bizmail.yahoo.com" in the Incoming mail server field and
      "smtp.bizmail.yahoo.com" in the Outgoing mail server (SMTP) field.
    11. For
      server field and "smtp.mail.yahoo.com" in the Outgoing mail server
      (SMTP) field.
    12. Enter your Yahoo user name in the User Name
      field. For a Mail Plus account, enter your mail address without the
      "@yahoo.com". For a Business Mail account, enter your mail address
      including the "@yourdomain.com".
    13. Enter your Yahoo Mail password in the Password field, then enter it again in the Retype Password field.
    14. Set
      the Remember password check box if you don't want to have to enter your
      password manually each time Outlook checks your mail.
    15. Make sure that the check box next to Log on using Secure Password Authentication is CLEARED.
    16. Click More Settings to open the Internet E-mail Settings dialog box.
    17. Click the Outgoing Server tab.
    18. Set the My outgoing server (SMTP) requires authentication check box.
    19. Select Use same settings as my incoming mail server.
    20. Click the Advanced tab.
    21. Make sure that Leave a copy of messages on the server is NOT checked.
    22. Make
      sure that This server requires a secure connection (SSL) is NOT checked
      under either Incoming server (POP3) or Outgoing server (SMTP).
    23. Click OK to return to the Internet E-mail Settings screen.
    24. Click
      Test Account Settings. The Test Account Settings dialog box appears and
      Outlook sends a test message using the settings you have just entered.
      If all is well, a Congratulations! message appears in the dialog box.
      Click Close to close this dialog box. If you didn't see the
      Congratulations! message, go back through this procedure from the top
      to check all your settings.
    25. Click Next then Finish.
I can not send E.Mails from my I.Pad
You need to make sure your SMTP settings are up to date in the email settings. Settings > Mail, Contacts, Calendar, then go to your email account settings.
Jul 13, 2013 | Apple Ipad I-pad
ALost all my emails from February , January 2011 as well as 2010,2009,2008 . I t has disappeared as well for my sent mail. I am using WindowsXP, email, sent mail , McAfee for anti-virus. Need everything...
What is the e-mail software?? Outlook Express or Outlook (Office)???, Than you need to give me more information as what happend, what you did, if it's Office Outlook you could try finding the .PST file somewhere on the drive, than point Outlook back to it...
Click (start), click (search), click (for files or folders...), use the search companion to search for a file with the (.pst) extenssion, if you find a .pst file it could be that one, than you need to point Outlook to it by opening (Control Pannel), than click on (Mail), click (Data files...) button, than the (Add) button, than choose Office Outlook personal folders (.pst) than click OK, now point to the correct file and save... every thing should be OK
Good Luck!
Apr 04, 2011 | Computers & Internet
I would like to set up outlook express with my yahoo account
Access a Free Yahoo! Mail Account with Outlook Express Using YPOPs!
To access a free Yahoo! Mail account with Outlook Express using the YPOPs! desktop utility:
* >> Step by Step Screenshot Walkthrough
* Install YPOPs! and make sure it is running.
* Open Outlook Express.
* Select Tools ' Accounts... from the menu in Outlook Express.
* Click Add and select Mail....
* Type your name.
* Click Next >.
* Enter your Yahoo! Mail address ("hmmzl34@yahoo.com", for example).
* Click Next > again.
* Make sure POP3 is selected under My incoming mail server is a ___ server..
* Enter "localhost" under Incoming mail (POP3, IMAP or HTTP) server:.
o If "localhost" does not work, try "127.0.0.1" instead.
* Type "localhost" under Outgoing mail (SMTP) server: as well.
o If "localhost" does not work, again try "127.0.0.1" instead.
* Click Next >.
* Type your Yahoo! Mail user name under Account name:.
o The user name is your Yahoo! Mail address sans "@yahoo.com". In this example, the user name is "hmmzl34".
* Enter your Yahoo! Mail password under Password:.
* Click Next >.
* Click Finish.
* Highlight localhost in the Internet Accounts window.
* Click Properties.
* Type "Yahoo! Mail" under Mail Account.
* Click OK.
* Click Close.
Useful YPOPs! Options
I recommend you also double-click the YPOPs! system tray icon to change a number of useful settings.
You can make YPOPs! ignore messages in the Bulk Mail folder of your Yahoo! Mail account, for example, tell it not to mark downloaded messages as read, fetch sent mail or have YPOPs! put a copy of outgoing mail in your Yahoo! Mail Sent Items folder.
Access Free Yahoo! Mail with Outlook Express Using IzyMail
To set up a Yahoo! Mail account in Outlook Express via IzyMail:
* Make sure your Yahoo! Mail account is registered with IzyMail.
* Type your name.
* Click Next >.
* Enter your full Yahoo! Mail address ("hmmzl34@yahoo.com", for example).
* Make sure IMAP is selected under My incoming mail server is a ___ server..
* Type "in.izymail.com" under Incoming mail (POP3 or IMAP) server:.
* Enter "out.izymail.com" under Outgoing mail (SMTP) server:.
* Click Next >.
* Type your complete Yahoo! Mail address under Account name: ("hmmzl34@yahoo.com", for example).
* Now type your Yahoo! Mail password in the Password: field.
* Click Next >.
* Click Finish.
* Highlight in.izymail.com in the Internet Accounts dialog.
* Click Properties.
* Go to the Servers tab.
* Make sure My server requires authentication is checked under Outgoing Mail Server.
* Go to the IMAP tab.
* Make sure Store special folders on IMAP server is checked.
* Type "_Sent" under Sent Items path:.
* Enter "_Draft" under Drafts path:.
* Click OK.
* Now click Close.
* Click Yes to download the list of Yahoo! Mail folders to Outlook Express.
* Click OK.
Oct 15, 2010 | Yahoo Messenger
Configure ms outlook 2007 to access my office mail it shows my inbox mail but dont shows my outbox mail or sent item & also contact list .Before outlook configure i access my outlook through web mail ....
ahhhh ok you want to access your Sent mail folder and contacts which you used when you used Outlook Web Access(OWA) "outlook through web mail" to connect to your Office Exchange mail server
in order to get this you have to configure Outlook 2007 to connect to exchange server. Do the following steps
  1. if you are running outlook close it as you can not configure exchange accounts when it is running
  2. if you are running vista, xp or 7 click on the start menu and right click on email and go to properties
  3. click on email accounts
  4. select "view or change existing accounts" click next
  5. click on any of the previously configured accounts and remove them
  6. click add
  7. select microsoft exchange server click next
  8. type name of the exchange server (you must get this from your administrator) and type in your username (name which you used to use through web mail) click on next
  9. click on finish
  10. open outlook 2007 and you should see all your previous contacts and sent items
hope this helps
Sep 24, 2010 | Microsoft Office Outlook 2007: Windows
I have forwarded all my inbox mails to outlook express,just for experiment,now i want them back in my yahoo mail inbox,and since than i cant recieve or send any mail please help me out manu india
There is no easy way. You must first go to account options in Outlook and set it to leave mail on the server. Then you have to manually forward every email back to yourself. The date will change and "RE:" will be added to each subject.
There is another option if this all happened today. First go to account options in Outlook and set it to leave mail on the server. Then have Yahoo restore your email.
May 21, 2010 | Computers & Internet
Outlook Express Send Mail Error
I've had the same problem, and my way to fix it was to turn of the firewall and check if it worked, and it did.
When I was sure that the firewall was my problem, I gave accsess to Outlook Express manually through my firewall.
I can probably help you with that to, but then I have to know what firewall/anti virus program you use (if you got one at all?)
Feb 17, 2009 | Microsoft Outlook Express
Problems sending and recieving mail in Outlook 2003
I am recieving some of my emails in my sent box not my inox.I am also using Outlook 2003
Nov 13, 2007 | Microsoft Outlook 2003 for PC
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
