The t.v. has a bunch of scrammbled lines from top to bottom. Sometimes a little stomp on the floor, are a shake of the t.v.(which i know is not good) clears it up for a bit. Just trying to get a little advice on what to do. It looks like when theres something scrambling your tv. The picture is there, but the lines make it a pain to see and rough on the eyes. It has gotten worse, I read were it may be a hyper module, if this is the case is it something I can fix myself, and if so how?
-   I'm having the same issue, Vertical lines separate 2 pictures that are scrambled, and horizontal lines moving down the picture constantly. Gets better and worse some days.-   Guest
May 17, 2008
-   horizontal banding seems the picture is all there just messed up
stomping the floor use to fix it now it needs a good beating!
what does this hyper module look like and where can I get parts? what is the part #
yes there is a hyper module,sounds like bad connections on the socket that it seats in or inside the module. remove and reseat and ESR the electrolytics....john
When the tv is on part of the picture is blacked out in the top left hand corner of the screen,...
(More)
When the tv is on part of the picture is blacked out in the top left hand corner of the screen, approx. 10x10?
I have a Toshiba 51H83 51-Inch HDTV-Ready TheaterWide Projection TV. The screen was broken and I...
(More)
I have a Toshiba 51H83 51-Inch HDTV-Ready TheaterWide Projection TV. The screen was broken and I need a replacement for it. Where can I find one? Thanks
jvc lcd tv model; no.lt-z32sx5 green pixcels come up and then no sound and goes blank standby light...
(More)
jvc lcd tv model; no.lt-z32sx5 green pixcels come up and then no sound and goes blank standby light stays on then i have to turn off from wall but comes back on but does it again?
turn the tv on and the picture is terrible. After 5 mins or so it gets better. Why is that?....
(More)
turn the tv on and the picture is terrible. After 5 mins or so it gets better. Why is that?. Squiggly lines make the picture terrible.
