Question about Toshiba 1370 Black and White Copier
Fix copier red wrench is always on. what can i do to fix this problem?
Re: fix copier
If it is always on, it probably means it overheated more than once. It's been a long time since I worked on those, but you have to clear the "C7" counter. The dealer will probably want $150 so they can reset it.
Posted on Oct 06, 2007
Re: fix copier - Toshiba 1370 Black and White Copier Printers & Copiers
Studio 350 codigo f100
Posted on Sep 18, 2007
  • 22 Answers
SOURCE: Red "wrench" indicator always on
Press the clear and the 8 button at the same time . This will give you a error code. I will guess that you have a "C7". If you still want to fix let me know error code.
Posted on Mar 17, 2007
0 characters
3 Points
What is the red wrench on the canon printer machine I need to scan ?
The red wrench means that there is an error message of some type. It could be pretty much anything...
Oct 07, 2015 | Canon Printers & Copiers
There are hundreds of error codes that will display call for service with a wrench. What is the error code on the screen?
Jun 22, 2014 | Toshiba E-Studio 456 Multifunction Copier
Red Wrench is lite on panel how do I fix that
mmmm'still you are using that model come on.Anyway that problem is about heater.
But because that's old try to trace the connection from it.
Buy a new for less headache.
Jan 12, 2011 | Toshiba 1370 Black and White Copier
Code "CE20" red wrench appears
This may not be the answer you want, but if you called for service and the tech did not fix the problem, the tech should return without a charge (if there was a fee).
For any service, for a computer, copier, auto or anything, if a service tech does not do his or her job and fix the problem. they need to return to complete the job.
Hope this helps.
Dec 31, 2010 | Toshiba Printers & Copiers
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
Good Luck and Thank You for using Fixya.
Dec 31, 2010 | Pitney Bowes C180 Copier
Ricoh Aficio 350e copier Multifuntion machine
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
Sep 08, 2008 | Ricoh Aficio 450 Copier
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Pansonic DP 8016
sounds like you need to have a PM done to the machine. there is a PM counter and when it reaches the 120K it will stop till you have a tech clean it and replace parts ans reset the counter
May 04, 2008 | Panasonic WORKiO DP-8016 Printer
Oct 25, 2006 | Toshiba 1370 Black and White Copier
Toshiba 1370 Black and White Copier Logo
136 people viewed this question
Top Toshiba Printers & Copiers Experts
Anthony Chiang
Anthony Chiang
Michel Smith
Are you a Toshiba Printer and Copier Expert? Answer questions, earn points and help others
