Question about Apple iPod nano
Won't connect to power
It's connected via a USB port, and the computer has recognised it, but it says Connect to Power and the battery is really low?
  • ali_brake Apr 19, 2009
    thank you :->
  • 342 Answers
Try reseting it while it is connected to your computer. simply hold the menu as well as the center button until you see an apple appear on the screen or for ten seconds.. if that fails your ipod is probably broken. leave it plugged in for a while any ways though and try to reset it again.
Posted on Apr 18, 2009
  • Mel Neilsen
    Mel Neilsen Apr 24, 2009
    Hell yeah glad it helped you. The ipod works fine now then right?
How do i connect my sat nav to the internet
The power lead should also act as a USB connected, connect via the USB port in your laptop or P.C and install the software, if you have no software disk then the software might be preloaded in the satnav, if so, the PC or laptop will recognise this.
Jan 10, 2015 | GPS
How to recharge my tom tom online
By online, I'm assuming you mean connected to your computer (via the USB port).
Just power on your GPS, then connect your GPS to your computer, using the USB port, and decline the CONNECT to Computer prompt. The GPS will then still be plugged into the USB port and the battery will be charged.
Aug 01, 2013 | Tomtom GO 720 GPS Receiver
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
Dos not work
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
hope this helps
Sep 05, 2012 | Eclipse Audio Players & Recorders
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
I got a windows 7 - 64 bit. the screenplay director hd media player from iomega doesn't show up when connected via usb. what should i do?
Quoted from Iomegas website
When connecting a ScreenPlay to the USB port on a computer, you should always power down the ScreenPlay first, then connect the USB cable and turn power back on. This changes the ScreenPlay from video mode that allows it to communicate with a TV set to USB mode that allows it to communicate with a computer.
When you want to reconnect the ScreenPlay to a TV, use the safe removal process for your operating system to unmount the drive, then power down the ScreenPlay and disconnect the USB cable. Turn power back on after the ScreenPlay is correctly connected to the audio/video connection on the TV set.
To ensure that the ScreenPlay is correctly recognized, do not connect a ScreenPlay to USB and a TV set at the same time.
Do the above and your screenplay director will be recognised by your pc
Please vote for me if you found this info useful
Apr 22, 2011 | Computers & Internet
How do you charge it?
I don't have this particular player, but most portable players can be charged by two methods. One is to plug it into your computer via USB, the other is to connect it to an AC adapter.
If you use the first method, be aware that some players need to be plugged into a "high power" USB port in order to charge. Most computers and laptops have a mix of high power and low power USB ports. High power USB ports are typically located on the back panel of the computer.
If you want to connect it to an AC adapter, there are many adapters out there you can use. You might want to Google for "NWZ-E344 charger".
Feb 12, 2010 | Sony Walkman NWZ-E344 Digital Media Player
When plugged into pc get error on pc power surge on usb hub port
Some computers have a limited power capacity on the USB ports, another possibility is that your gps battery is too low to be charged via the USB connection, try charging it with a wall or car adapter first, then connect to your pc.
Jan 10, 2010 | Garmin nuvi 250 GPS Receiver
Will not connect to computer device not recognised
make sure you are connection to a USB 2,0 port and not 1.0
if you are connecting via a HUB then ensure that the hub has its own power supply.
also try a different cable if you have one
You may also have to re-install the software
Aug 09, 2009 | Tomtom GO 720 GPS Receiver
Transfer video from cam to pc via 1349 cable
my computer recognises handycam when i connect via usb. but iam not able to connect via ieee1374 cable.in im ycom,devicemanager, there is no imaging device when i connect via iee1374 cable.do i need some drivers or in need to make some changes in cam settings.my comp is
amd athlon 64 bit, 700mb ram, dvd ram drive,my 1374 port is with via chipset.
Apr 01, 2007 | Sony DCR-HC32E DV Digital Camcorder
Apple iPod nano Logo
60 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
