Typewriters
Problem for Typewriters
Generic problem for all Typewriters
IBM Wheelwriter 15
By CopierOne on Sep 17, 2007
The machine won't print the Number 9, the letters O and L and the period. The keys that won't work are in a line and makes me think that it might be a cable problem or a keyboard. Any help would be greatly appreciated.
Aloha,
Bill Monroe
Comments:
Sep 30, 2007
- That was indeed the culprit. I lifted the rear part of the keyboard up and the ribbon connector between the keyboard and the control board was partially pulled out of the socket. Also the two larger ribbon cables that are also connected between the KB and control board were really tarnished. I cleaned all of the connector ends with an eraser and reconnected them and all was good. Thanks for the help.
Same Problem
Jun 30, 2008
-   Wheelwrirter 15 and the 6 & 7, y & u, h & j and the n & m do not work. -   rdhammel
Best Solution
posted on Sep 27, 2007
Very Helpful)
JayBlair
Rank: Wiz
Rating: 82%, 269 votes
Keyboard connectors are not fully seated in main board or you need to replace the keyboard. You can send your board in for rebuilding for a cost of about $75.00.
Was this helpful?
Yes
No
Popular Solutions for Typewriters
Questions and Unsolved Problems for Typewriters
Answer
i have a royal safari circa 1960s typewriter and need to find replacement ribbon. where do i go?
Answer
wheelwriter series II when I hit return the carriage moved all the way to the left and the machine... (More)
Answer
Carriage moves to the left. Buzzes for a few moments then stops. Beeping noise, line spacing leds... (More)
Answer
Shift lock stuck on my Royal Quiet Deluxe
Answer
I have an IBM Executive Model C typewriter that will not run. I plug it in and turn it on and... (More)
Describe your Typewriters problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Typewriter Experts
Top Copier & Fax Repairmen
in Newport, KY
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
