Processor Clockspeed Down
My processor's clock speed is 2.53ghz, when i boot up my computer's processor actually runs at a 2ghz clock speed intel ID utility detected it but after 10mins or so my processor's clock speed drops down to just 1ghz of clockspeed so i wanna know if there's anyway that i can fix this, by the way my processor is intel celeron d 2.53ghz, hope you can help me thanks
  • kristian7238 Apr 18, 2009
    my computer is a desktop, it's just assembled not branded
  • 432 Answers
If you go into the bios you can disable speed step if this is a laptop otherwise you would have to check the manual for the laptop to see if there is anything else you can do.
Also if you post back with make and model of the computer and whether its a desktop or laptop that would help
Posted on Apr 18, 2009
What's your problem?AMD athlon 2Ghz processor will suitable for asusp5gc mx x-series motherboard
No... Absolutely not.
You can't put an AMD processor in a motherboard that only supports Intel processors.
Aug 17, 2012 | Intel Computers & Internet
Can u explain the growth of the pentium processor with respect to the pentium pro, pentium II, pentium III, pentium 4 and the pentiuim 5
the prcessory varies with clock speed and the speed for example a pentium 1 processor has a spped of 100mmx with aclock speed just 66mhz now the pentium 4 processor uses a spped of 3.0 ghz with a clock speed of 800mhz so there is deferance as the clock speed increase the speed of the computer increases
Aug 31, 2011 | Intel Pentium IV M, 3.06 GHz Pentium 4-M...
The clock speed on Windows 7 Ultimate shows only 1.60Ghz
It depends on the processor you have installed. Dual or Quad core processors are slower e.g. a dual core listed as 4GHz is actually 2GHz per core. With laptop processors, if they have Speedstep technology then the speed will vary depending on the processing power required.
Mar 03, 2011 | Computers & Internet
I have asus M.b p4 sys133 and it has a 2.00 MHZ processor .. when i gave changed it with another with 2.62 MHZ it didn't work and the computer was hanging .so what's the problem ???? the processors were...
Hi there.
The computer is probably struggling with the clock speed of the new processor.
Did you reset the BIOS setting?
If you didn't go into the BIOS and set it to default settings, hit F10, save the changes and restart the computer.
Clock speeds should now be reset and the computer should work. Also you should make sure the system memory is seated properly.
Good luck
Jun 10, 2009 | ASUS (S370L) Processor Board
My processor's clock speed is 2.53ghz, when i boot up my computer's processor actually runs at a 2ghz clock speed intel ID utility detected it but after 10mins or so my processor's clock speed drops down...
The reason for this is because you CPU needs to run only at 1Ghz at that particular moment. see the more programs you run, the more processing is needed. No if your computer is on Idle then the or have programs like word or excel running the processing is less. so the CPU automatically reduces the processing speed. this way the CPU is energy efficient. you have nothing to worry. this is a feature that Intel has added to the newer generation of CPU's
May 13, 2009 | Computers & Internet
USES only 2ghz instead of 3
Have you just installed this processor as an upgrade?? Check the jumper settings on the motherboard and the multiplyer in the bios.You need 133Mhz clock speed. With the multiplier of 23 which is set in the bios automatically by the CPU id 23x133 = 3.06Ghz. I suspect that the jumper settings are for 100Mhz so 100x23 = 2.3Ghz. Let me know how you get on or if you have any more questions as i have the same motherboard and im gonna buy one of these processors @ Lecousi@yahoo.co.uk
Regards
Lecousi
Feb 18, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I have a 945GCT-M/1333 motherboard but my processor is a Intel Pentium 4 - 2.66mhz and it seems to run for a little while and then shut down the entire system. I am running a Ram chip 1GB speed 533MHz...
I always suspect overheating first in these cases. Are the fans, especially the fan on the cpu heatsink running?
You can check the system temperatures on most systems by booting the PC and entering the BIOS setup ....often by pressing the DEL, ESC or F2 key repeatedly as it starts up (the screen will tell you . which key to press to enter setup) . In the BIOS setup navigate to the "HArdware Monitor" or "PC Health" section. Watch the CPU temperature. On idle in the BIOS setup the temperature really shouldn;t go above 40C.
If it's a lot higher than this then the CPU heatsink fan needs attention.
Dec 31, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Processor Upgrade
did you reset the bios first. ? (id pull the coin cell)
you did all that backwards , the steps are.
1: read the HP service guide see all processors supported.
its a short list. its not like changing light bulbs.
2: the BIOS must support that precessor too.
3: the upgrade if possible , SEE?
d530 SFF, is a small form factor desktop.
it came with
Intel Pentium 4 2.8 GHz
my guess is you want the 3.3mHz version. ( a wasted effort and cash in my opinion the ,it is only fractionally faster, (go for 2 or 4 cores and win)
these old PC are mostly NOW scrapped, gone, nobody wants them.
for good reasons. (no support and no parts, and slow as slug)
worse is it runs XP the dead, now, virus magnet.
support at HP says.
HP COmpaq EVO Business D530
circa 2003, 14 years young?
some sold with Windows 2000. ! ouch and Mandrake 9.1 Linux - Light and OS/2...
specs. that matter
Intel 865G Chipset
800-MHz, 533-MHz or 400-MHz FSB (front side bus limits)
and the memory must match it. speed wise.
the parts surfer (HP ) shows it cam with 17 processor options.
sold newer, the full p/n in the service tag tells this.. not told by you.
some Celeron and other P4s.
the fastest one is, (HP P/N#)
335813-001
Intel Pentium 4 processor - 3.20GHz (Northwood with Hyper-Threading, 800MHz front side bus, 512KB L2 cache, FCPGA2, Socket 478)
the problem with that is the BIOS, many times the newer faster
the hp support page is active.
the last BIOS update is for just this, processors
eg: BIOS 109
Updates Intel Pentium 4 Processor microcode for F41, F34, F29 and F49 steppings. (cupid app shows this)
getting the BIOS correct first is hard.. due to variances, in mobo
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-d530-small-form-factor-desktop-pc/316713
lession1:
when PC boots, the BIOS scans many thing but CPU is #1
it scans it to see if it recognizes, it.
if it can not do that, (not in its old 2003 list) then it defaults to slowest CPU support, what else can it do?
the it sets up clock rates properly, this is super basics in PCs.
Then it scans the memory sticks to see if they can run at this clock rate, if not it goes to slow speeds. (what else can it do ?)
it will go to the slowest ram stick inserted. speeds.
or to slowest processors you have actual.
that is all.
Aug 24, 2017 | HP Compaq d530SFF PC Desktop
How can I overclock my 166mhz classic computer?
Overclocking is not really recommended to be done by normal users. For overclocking your computer, you should have extensive knowledge of the hardware of your computer.
Overclocking may result in a totally non-working computer, burnt up Processor and motherboard and the likes. Also, overclocking results in heating problems, so you need to have made the arrangements for taking care of this heat issue.
Basically overclocking means increasing the Clock Speed of your comuter. Suppose I say that I have a Pentium 4 - 2.4GHz computer, the 2.4GHz part is the clock speed, which is increase in overclocking. Surely the computers with higher clock speeds work faster but that comes at a price. A small mistake on your part and your computer is no more working.
There are various Forums and sites on the internet that discuss Overclocking and its intricacies in greater detail.
Here's a pointer:
http://www.extremeoverclocking.com/
PS: Search google for "overclocking" and you should get a lotta links to work with.
Oct 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I have put a sempron 3.4 processor in but the system only recognises it as 2ghz ?
Your processor speed is actually correct AMD calculate the clock speeds differently from Pentium type processors, a 3400+ is a 2.0 GHZ processor, see the list below for speeds Sempron 2500+ 1.40 GHz 800 MHz 128 KB 754 Sempron 2600+ 1.60 GHz 800 MHz 128 KB 754 Sempron 2800+ 1.60 GHz 800 MHz 256 KB 754 Sempron 3000+ 1.80GHz 800 MHz 128 KB 754 Sempron 3100+ 1.80 GHz 800 MHz 256 KB 754 Sempron 3300+ 2 GHz 800 MHz 256 KB 754 Sempron 3400+ 2 GHz 800 MHz 256 KB 754 Don't worry too much about the proceesor not being recognised as long as you know it is running at the correct speed.
Nov 12, 2006 | Iwill ZPC-SP (ZPCSP) Barebone
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
