Question about Konica Minolta magicolor 2430 DL Laser Printer
Konica Minolta magicolor 2430DLshowing Fatal o8h
Have a Konica Minolta magicolor 2430DL and it is showing Fatal Error Code: 08H. What does this mean and can I fix it myself
  • 44 Answers
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Posted on Apr 20, 2009
Haw can sole my fatal 14 error in konica minolta
Check the transfer roller a sponge looking roller across from the transfer belt
Sep 21, 2015 | Konica Minolta magicolor 2430DL
Model 2530DL - Fatal Error Code 08H - help!
Worcesterlad came up with this some time ago: it's not a solution but somewhere to investigate:
Jul 14, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error 12H on Konica Minolta Magicolor 2430DL
This error (12H) pertains to the Laser Unit of the printer which is damaged and needs to be replaced. The Laser Unit is the heart of the printer, it's what transmits the image to be printed. You need to contact a service center and will run you about $200. I had this same problem with my printer and had to call Technical Support and they gave me the bad news
Oct 26, 2008 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error - Code: 2AH
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
Sep 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
510 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
