Question about Palm LifeDrive Handheld
Lifedrive wont read anything in expansion slot
Whenever i insert a sd card into my lifedrive it makes the noise to signal that it understands you inserted a card ( the device only signals a card has been inserted like every other time ) but then a error message comes up saying : the startup application for this card cannot be run --- i have no idea what application is missing to read the sd card i have tried to research and find information on this and the only thing i can think of is the fat32 driver that reads the card is missing
  • imforcanada Oct 11, 2007
    already formatted the card and did a soft reset on the device
FOrmat the Card and see if it works
Posted on Oct 10, 2007
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Can not remove sd card from storage expansion slot
Push the card in just a bit until it clicks, then it should release unless it is stuck. Sometimes this happens with new SD cards until they are inserted and ejected a few times.
Mar 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
LifeDrive will not recognize SD expansion card
If the sdcard is the right type and size all you need to do is fully insert it into the slot. Its spring loaded so it will pop up if it isn't quite far enough in. It should only fit one way.
Generally the LD likes 2gb and smaller sdcards , it can use bigger such as 4gb but that's when you can be hit or miss. That depends on brand and sd version.If you search for a list of LD compatible sd cards you should find out what card to use or buy.
Jun 17, 2008 | Palm LifeDrive Mobile Manager Handheld
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Memory expansion slot
If the SD card is a compatible type, it should just read it
May 10, 2007 | iLO (2 GB) MP3 Player
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm LifeDrive Handheld Logo
156 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
