Fujitsu 24R1 Air Conditioner
Problem for Fujitsu 24R1 Air Conditioner
Air conditioner not blowing cold air anymore
By justinmw316 on Apr 18, 2009
I have a fujitsu ASU9RLQ split air conditioner and was wondering what it means when the timer light flashes 3 times in a row during operation? It is no longer blowing cold air, so i am assuming that the timer light flashing 3 times is some sort of error code, just cant find it anywhere.
Same Problem
Apr 30, 2009
-   i have a Haier a/c, even if i have it on hi/ac and max/cool it's working like a fan, not cold air blowing, thanks -   RunBoyRun
Best Solution
posted on Apr 18, 2009
Very Helpful)
louislevel_2
Rank: Guru
Rating: 88%, 223 votes
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Fujitsu 24R1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 24R1 Air Conditioner
Do you recommend Fujitsu 24R1 Air Conditioner?
Answer
Answer
Look for someone to repair Ionic Breeze Quadra Silent Air Purifier.
Answer
My reversecycle wall air conditioner (not split) is blowing air but the air is neither cold or warm.... (More)
Answer
celiera 12000btu 35x,installed and have 115volts to inside and outside units but wont turn on
Answer
I have a CELIERA split wall a/c unit.... I need a remote control, do you have any info on where i... (More)
Answer
I have model #AST24RGB-W. It seems to work ok, but while the fan is not blowing it makes a constant... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
