Question about Brother MFC-3240C All-In-One InkJet Printer
Reprinting a fax
I received a fax a little while ago and would like to reprint it because it didn't turn out well. How do I do that?
  • Anonymous Mar 12, 2014
    can I reprint a received fax
    Scholar:
  • 68 Answers
First of all how do you have your 4 in one set up? Do you have faxes so they spool to your hard drive or print directly from your printer? Some fax machines have there own memory. I must mention though this amount of memory is very small. If you use your fax machine alot then your document may be lost. However if you spool to your hard drive you will be able to bring up the utility for your 4 in 1 and it will have the document date and time.. click on it and it will bring it up usually in a word processing format and you can print it from there.
Posted on Sep 22, 2007
SOURCE:
NEED TO REPRINT RECEIVED FAX HP OFFICEJET 4500
Yes, You can.
Press Settings (The Wrench Button)
Navigate to "Print Report" - Press OK
Navigate to "Reprint Faxes" - Press OK
"Reprint All Faxes" - Press OK
Or Navigate to "Reprint One" - Press OK
Navigate to Date/Time Received of fax to reprint - Press OK
May 19, 2012 | Brother IntelliFax-2820 Laser Fax
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
How do i reprint a fax from my lexmark X5470
I'm sorry to inform you that the Lexmark X5470 does not have the capability of reprinting previous fax messages. You can, however, contact the sender and have the fax sent to you again.
May 27, 2011 | Lexmark X5470 All-In-One InkJet Printer
Cannot retrieve documents received today in memory
What make a model is your fax machine? Do you have a copy of your user manual? If yes, have you checked it for reprinting from memory? If not, downloading a copy of the user manual would be your first step to solving your problem. It will either tell you how to reprint the fax or that you cannot reprint the fax.
Jan 26, 2011 | Office Equipment & Supplies
Can I reprint a fax that I just received?
If you want to reprint a fax because the print cartridge was empty or if the fax was printed on the wrong type of media, you can try to reprint it. The amount of memory that is available determines the actual number of faxes that are stored for reprinting. ... These faxes are stored continuously.
here's how if you have this accessibility..
Press "Setup" on the control panel of your fax machine. Most fax machines will have an LED display panel on the front of the machine. The panel will usually include on screen prompts and help options. Some fax machines signal the user if they have faxes stored in memory and prompt the user to "print faxes" or "clear memory," but you need to make sure that you don't accidentally clear the memory or you will lose all saved faxes.
Use the arrow keys or number pad as directed by screen prompts to select "Fax Setup Menu" and then press the "OK" or "Start" key.
Enter the security code, PIN, or user authorization code if required. The security code or PIN protects sensitive information and prevents unauthorized use of the fax machine memory. If you haven't set it up you don't have it.
Navigate to "Receive" or "Print Faxes in Memory" and then press the "OK" or "Start" key as directed by the on-screen prompt. The last fax stored in the machine's memory should begin to print.
Repeat the above steps for each fax in memory if you need a different one.
Hope this helps and isn't clear as mud!
Happy new year.
problem? make and model # please.
Jan 01, 2018 | HP Officejet 4110 All-In-One InkJet...
Fax reports
Hi Jambo,
Please click on the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04517&cc=us&lc=en&dlc=en&product=79477#N1605
Click on the Reprinting faxes in memory and check the steps to print the faxes stored in the memory,
For further information you can go through the web link given above for the detailed overview of faxing.
Have a great day!
Mar 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
REPRINTING FAXES
Anica I'm Sorry machine does not store fax's unless it has not printed them, it only stores transaction record with details like time, page qty and number received from, not a fax image
Dec 14, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Paper jam in B155 faxsmile
What kind of problem are you having?
Jun 07, 2007 | Canon FAX B155 InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
336 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
