Question about Samsung Televison & Video
Tv switching off automatically
I have a bpl tv 26'' it switched off automatically. i took it to the nearest local mechanic and i was reported a problem with power supply unit. got it back after repair and after running for 6 hrs the problem appeared again. got the same repair done and bought home. but the problem continuing. once again my tv is powered off.
  • 700 Answers
He might miss something on the power supply could be overheating . This erratic behaviour can also be attributed to loose solder connection on vertical IC. Ask him also to reflux its pin.
Just for an input.
Posted on Apr 18, 2009
BPL TV NOT STARTING
if no any power indicator that light or even blinking, the first place to be check will be the power supply section you must check weather the fuse is blown.if the fuse is blown before you replaced with new one you need to check other component in the power supply section like transistor and diode. so this case need proper trouble shooting, if you think you don't have enough idea in any electronic repair just leave it to the trained tv technician.
Aug 12, 2012 | Televison & Video
How to switch NTSC PAL on BPL Neptune TV
If the set is able to be switched it will be in the main menu but most sets with dual features will automatically detect the signal and change on their own.
Jun 13, 2012 | Televison & Video
Bought a 26 inch proscan from Costco on line. Tv won't turn on, led light is off as well. own TV approx 2 years wah can i do besides leave TV curbside?
Hi sglassgold,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated. I would advice also to replace the entire power supply for your convenience if finding technician there is not possible.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 14, 2011 | Proscan 26LB30H 26 in. LCD TV
I turn tv on then the standby light goes green then goes to red flashing
It is a common Fault on some lcd tvs you will need a replacement switch mechanism fitted don't know the correct name for it but it can be fixed .I had exactly the same problem with my BUSH 26 inch LCD tv took it to a local independent tv shop and the owner repaired it for me it cost around £67 if my memory is correct this fault started on my TV 14 month after i bought it - 2 month out of warranty. hope this response helps
Good Luck
Eddie Hall
Nov 27, 2010 | Televison & Video
BPL PSM ON problem
Picture Status Memory(PSM): Selects excellent preset picture controls for multi-media, personal, movies, sports, and weak signal programs. usually on remote control, or in TV setup.
You need to use your manual and turn it Off.
Apr 18, 2010 | Televison & Video
Bpl service menu code
press one time display key and three times mute .service mode will open
Feb 27, 2010 | Hitachi C25-RF35S 25" TV
BPL TV MODEL FQR 21 don't start due to moisture
i have a cpu but my monitor has been broken so i wanted to connect my Bpl feb 21 tv can i?
Sep 09, 2009 | Televison & Video
AC Blowing Warm Air
the refrigerant gas is not enough . need recharging.
Jun 16, 2009 | 2002 Chevrolet Tahoe
How to switch off psm in bpl tv?
I HAVE BPL TV FZR 21. IT IS LOCKED. HOW CAN I UNLOCK IT
Jun 02, 2009 | Samsung Televison & Video
Televison & Video Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
