Question about Intel D845GVSR Motherboard
My mother board is intel 845GVSR.msg displays turn off the power and reinstall the jumper in normal mode position
  • 3,267 Answers
Did you short the BIOS memory? In that case it hasn't been put back properly.....sodeep
Posted on Apr 18, 2009
Turn off power and reinstall the jumper in normal mode position what can i do???
you should short the pins on the mother board the deatil are as below the + wire and the ground wire
Oct 13, 2010 | Intel D945GCCR Motherboard
Intel DesktopBoard D845EPI Problem automatik open Bios
change jumper to its normal position then plug out ur powercable,now u see there is 1 battery in motherboard just remove it and start pc for a sec and then shutdown again and put battery back,start ur pc and check
Mar 07, 2010 | Intel Desktop Board D845EPI Motherboard
Hello, I have updated BIOS of Intel 845 GVSR board. But after the successful update USB is not displayed in BIOS hence no USB device is getting recognized. Please help.
Had exactly the same problem. This process fixed it for me:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/tech_reference/box_processors/int_inst_info/factory_notes_all/203939.htm
  1. Shut down the computer safely and remove the chassis cover.
  2. Move the BIOS Configuration jumper to the Maintenance position. (Refer to the Quick Reference Guide or Product Guide for the location of this jumper.)
  3. Power on the computer and enter BIOS Setup (press F2 during boot).
  4. Go to the Advanced > USB Configuration menu.
  5. Enable the USB Function.
  6. Go to the Exit menu and select Save Custom Defaults.
  7. Save and exit the BIOS setup.
  8. Turn off the computer.
  9. Move the BIOS Configuration jumper back to the normal mode position.
  10. Power on the computer and enter the BIOS Setup again to verify that the Advanced > USB Configuration menu is now back to normal.
Jan 06, 2010 | Intel Motherboard
You have installed the jumpers in incorrect way,please install with correct way.Keep one piece of jumper in certain chips to set down on mother board.
So keep so care with installing it.
Nov 18, 2009 | Intel DG31PR Motherboard
i get jumper the error massage is " Turn off power and reinstall the jumper in normal mode position
Sep 10, 2009 | Intel D945GCCR Motherboard
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Nov 20, 2008 | Intel DG31PR Motherboard
Intel D845GVSR Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
