Question about Philips VOIP8411B/37 IP Phone
Phillips VOIP841 skype phone
I have a new Phillips VOIP841 internet phone that I use with skype. 'The trouble is that , after working well for several days, it suddenly seems to be stuck at "system is starting up". it never goes past this!!! When I try to see anything with skype - contacts, etc. it gives me a red exclamation and unavailable. I can't change date or time or anything else because i get the red unailable. I've tried taking out the batteries and starting over but no luck!! What do I do to get my phone working again?
  • 5 more comments
  • Anonymous Sep 15, 2008
    The same issue of"System is starting up" message. I am able to solve it by switching off the base unit,internet and then removing handset batteries for 30 seconds. Then switching it on..it works for a day. Over night it goes into the same mode again. I also held the reset button in the base and it cleared all settings and again it worked for a day or 2. But wats the permanent solution? I cant believe there is no  firmware update. I shuld have gone with vonage...
    Date: Sep 15 2008
  • kfuruno Nov 08, 2008
    I have exactly the same problem... I have tried all the posible solutions stated below but anyone is working... So, how did you solve it? Thanks!
  • Anonymous Dec 14, 2008
    System is starting up forever, no functions like contacts available. I can phone though ...
    Reset does not help, not on unit and not on base station. Baaaaa
    Ender
  • Anonymous Dec 25, 2008
    i checked skype forum, many people said that this kinda problem could be solved by firmware upgrade (even if you have the latest on your unit), but i upgraded twice, nothing helped, i just unplug the unit everyday to use this phone
  • ruuddear Feb 06, 2009
    goes past this!!!
    and unavailable.
  • mpirmohamed Feb 11, 2009
    Before starting Solution # 4, I disconnected everything. even removed batteries. Solution # 4 did not work at first. Registration failed several times. While it was trying to register, I continuously pressed the page button for a minute or two - and it worked!
  • jamnsu Apr 11, 2009
    I have exactly the same problem, tried to phone Philps service until now without success if I find the solution will tell ya!
    Problem Solver:
  • 5 Answers
DeRegister the handset and then reregister it to the base
On handset
Menu
Settings
Handset
Deregister
Then
1 ) press Reg. Register shall be highlighted.
2 ) press Page key on the base unit until the two indications turn off.
If registration is successful,the signal icon Phillips VOIP841 skype phone - 070928095554_21019.bmp displays steadily.
If registration failed,repeat the above procedure.
Posted on Dec 31, 2008
There's a reset button on the base unit. That worked for me. You have to press the 'page' button to connect to the handset.
WH
Posted on Oct 20, 2007
I had the same problem and managed to solve it by chance: I pushed the button on the bottom right of the phone (the one with a key and a #) it asked me if I vanted to unlock the system und to push the *a/A button to do thie. And it worked!
Good luck
jamnsu
Posted on Apr 11, 2009
I had something similar. After trying several things, I figured out, that the power socket of the skype box was little shaky in my case. I had to replace the adapter, because of different voltage in Germany. Maybe the new plug doesn't fit exactly. After fixing this, the connection is stable again. Worth to check it.
R.
Posted on Jan 20, 2009
I tried both the Reset button on the base and the Unplug the power to the Base Unit.
The Reset button gave no results, but unplugging the power to the base and waited for a minute or two, the system started up normal again.
Hope it helps
Posted on Jul 02, 2008
Try unplugging the power on the base unit (not the handset, the other unit), wait for a few seconds then plug the power back in. Hope that helps...
Posted on Sep 18, 2007
SOURCE:
Philips VOIP841 user guide
visit the below link
phone.manualsonline.com/manuals/.../philips/voip841_1_2.html
Nov 27, 2009 | Lands Phones
Http server password for VOIP841?
try this...
User:philips
pw:voip841.
Jan 09, 2008 | Philips VOIP8411B/37 IP Phone
Philips VOIP 3212
The VOIP321 from Phillips does NOT connect to your wireless router. It requires to be plugged into a USB port on a WINDOWS ONLY desktop computer, which needs to be left on/logged-in with Skype running to send and receive calls. It wont work with Vista either.
Additionally Since Skype Version 3.8.0.188 (Release date: November 19, 2008) and all later versions (including Skype 4 Betas) the software Phillips supply no longer works with Skype and the VOIP321 phone. The latest VOIP321 <a href="http://tinyurl.com/6b2xrp" rel="nofollow">driver from their website</a> suffers the same issue, even though it states "The VOIP321 USB Phone Driver V 3.8.3 which can be downloaded from Philips web site is compatible with Skype software version from V2.0.0.x until V3.8.0.x". This is plainly no longer correct with the latest stable release of Skype, V3.8.0.188.
Skype developers are <a href="https://developer.skype.com/jira/browse/SPA-599" rel="nofollow">unable to do anything about it</a> and Phillips wont update their driver (Quote "... no more development/fixes are being incorporated into the VOIP321.EXE file"). Phillips would probably rather sell you a newer bit of hardware.
Don't waste your time on Phillips Skype phone devices, as their driver support is lacking when Skype is updated, so you buy a product for a few hundred dollars and it becomes useless 12 months later.
Another reason to not purchase the Phillips Skype phones is that it is Windows Only. No Mac or Linux support or drivers offered.
Dec 16, 2008 | Philips VOIP3212 IP Wireless Phone
VOIP321 - "ACCESS TO SKYPE DENIED"
http://www.support.philips.com/support/html/index_us_en.html TRY HERE.RICHARDM69
Dec 06, 2008 | Philips VOIP3212 IP Wireless Phone
Problem with philips voip841
Try retrieve the IP address of your VOIP841, on the handset press the “Menu” button, navigate to the “Settings” menu and choose the option “Network”, then "DHCP", it should give you an IP address, make a note of this. Open your Internet browser and type in the IP Address of the VOIP841 into the address bar. The Internet browser will show the internal Internet page of your device. Login with the following username and password:
Username: philips
Password: voip841
After logging in please navigate to the “Skype” menu option in the left side menu. On this page y ou can type your Skype username and password. Once they are filled in save your settings and test on the handset if everything is working.
Sep 25, 2008 | Philips VOIP8411B/37 IP Phone
VOIP841 will not register
Probably there is typo when entering user name or login. Check and see perhaps there are some unnecessary spaces in user name or password.
Also make sure internet connection is on and working + router is configured to accept new connection.
Aug 06, 2008 | Philips VOIP8411B/37 IP Phone
Connection
You only need a router and a DSL connection (with a Philips VoIP841). Have a look to this review:
HEXUS.lifestyle - Review :: Philips VOIP841 PC-free DECT/Skype phone - world's first review : Page - 4/4
HTH
Ennio
Jan 04, 2008 | Philips VOIP8411 IP Phone
Phone not picking up contacts
Remove the batteries from the handset for at least 1/2 minute and reinstall them bach. This should work The contacts will show up again on tehe handset.
Dec 16, 2007 | Philips VOIP3212 IP Wireless Phone
Voip841
Yes, If your phone supports SIP then you should be able to program any service provider. On the other hand if this is a Skype only phone then you will not be able to use it with any other service besides Skype because they use a non-standard protocol.
I tried looking up your phone and the closest I came was :
http://www.amazon.com/Philips-VOIP8411B-37-Phone-System/dp/tech-data/B000ND75FW/ref=de_a_smtd
This says in the Tech Specs that it is voip client and softphone compatible (whatever that means). It doesnt say it is SIP compatible. So look up the user manual and if it says that your phone is SIP compatible then you should be able to program any VOIP service provider (90% of them are SIP based) but if all the manual mentions is Skype and nothing else, then you might be out of luck.
Hope that helps!
-AM
Nov 29, 2007 | Philips VOIP8411 IP Phone
Philips VOIP841 Cannot connect to Skype - Adsl problem?
Right. I've fixed it!
Here's what I did.
- You need to upgrade to the latest firmware. This is available from the Philips website. Make sure you select exactly the model of your phone. There are some instructions about how to upgrade the firmware in the manual
- Then you need to perform a reset of the system. ie: get a sharp tool and ram it into the tiny little hole on the black box which comes with the phone. If you don't do this after upgrading, it doesn' t work.
- One other tip is to check the firewall settings on your router allow the traffic in/out as well.
I called the Philips service center, and they were a bit useless, but they said if it doesn't work you could try taking the batteries out of the phone for 4 hours. Hmmmm... only try this if the above doesn't work!
Good luck.
Oct 27, 2007 | Philips VOIP8411B/37 IP Phone
Philips VOIP8411B/37 IP Phone Logo
2,663 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
