Question about Sony DAV-SC5 System
DVD Function Not Working
There are four functions: Video 1, Video 2, Tuner and DVD. When we switch to the DVD function nothing happens. When it used to read the DVD and the display screen would say 'Ready!' or 'Reading' or 'Eject' there is nothing. It is completely blank. The screen is also blank. There is a DVD in Disc3 right now that we can't get out. The system does not respond to anything that has to do with the DVD function. Also, when we try and shut it down it just flashes 'Standby' and never shuts off. I left it like that for two days when I went somewhere overnight to see if it would eventually shut down but it was still flashing 'Standby' when I came back. The only way to turn it back on after that is to unplug it and wait a few moments before plugging it back in. Video 1, Video 2 and Tuner are all working perfectly. I have no idea what is wrong with it since it has sat on the shelf and never moved since I bought it... Someone help?
  • 7 more comments
  • olliblue Nov 16, 2007
    Hi
    Same problem here !
    Anyone have a tech diagram ?
  • Anonymous Nov 24, 2007
    i have same problem as well, very annoying and cant watch dvd through it! Cant solder either so a but stuffed! They should definately recall them!
  • viggo jensen Nov 24, 2007
    Have the same problem, fixed under warranty but fault returned 3 months later. Wouldn't mind but I hardly used the DVD. Contacted Sony & fobed me off, they say never heared of problem, what a load of rubbish!
    Located ic & pin 203 but where is the 3.3v line located?
  • marneesmith Jan 16, 2008
    Had same problem, started with locking up after several chapters on a disc and then total failiure. Purchased a resistor 13pence and took the cover off,i located ic206 on the lower board beneath a shield/heat sink, and soldered a fly lead to pin 203, this required a very fine soldering iron, good light and amagnifying glass.the 3.3v line is located on the white multi pin socket on the board. pleanty of space here to fit the resistor and connect the fly lead. This was a perfect fix for me, Many thanks "GUEST"
  • Anonymous Mar 02, 2008
    same problem!!
    no dvd player, always tries to eject disc when your trying to load it!!
    did find the eject button stuck in, released it but to no avail!
  • Anonymous Mar 07, 2008
    will play a cd and then nothing. Only way to get it to respond is to cut the power off at the wall.
  • Anonymous Apr 17, 2008
    wont play dvd disc it just ejects it and won't load
  • ducatisti Jul 05, 2008
    I can not insert a CD or DVD lately. The system goes on stanby and nothing happens anymore. Have to unplug to use other functions but the VD player is more or less not usable at the moment
Help me!
Dav sc5 problema:dvd player no pictures scart and rca out,but have sound(rca out)
Posted on Jul 01, 2008
The resistor solution worked a treat, well worth trying.
Posted on May 19, 2008
Had exactly the same problem after I had the unit about one year, fixed under warranty, then the problem recurred about a year later. Found this tip on another message board " If you solder a resistor of 820ohms between pin 203 of IC206 to the 3.3V line your'e problem is gone." Tried it & to my surprise it worked, a $0.06 part, Sony should have recalled this product. FYI, IC206 is on the lower of the two PCBs in the back left corner.
Posted on Oct 24, 2007
SOURCE:
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
Sony dvd player dvp-fx810 stuck on "disk loading"
Make sure the switch on the side is set to video out not video in hopefully this helps out
May 16, 2009 | Sony DVP-FX810 Portable DVD Player
Ps3 won't read disc
When Blue ray disk is placed into slot it seems like it is going to work and the screen on tv shows the entro for sony but nothing happens. Controls on controller will not function.
Apr 29, 2009 | Sony Playstation 3 (PS3) Console
Trouble with Tuner 2
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
May 14, 2008 | Samsung SIRS4120R Receiver
Lost audio when playing DVD....
you got your rca's crossed someone was behind receiver and tv
there on the wrong jacks
May 13, 2008 | Yamaha RX-V800 Receiver
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Cant open up cassette
There are positions on the rotary switch that determine whether you're on the hard-drive or the mini-DVD functions. There's even a small switch (to the lower left of the rotary dial) that keeps you from accidentally switching to the DVD functions.
Make sure you're dial is all the way to the left and reads "DVD". Once you're set on that, the disc eject button should work.
Dec 16, 2007 | Hitachi DZ-HS300A DVD Camcorder
Sony DAV-SC5 System Logo
1,128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
