Cannot remove blades
Cannot remove fan blades from a holmes bionaire bsf152t stand fan. taken the front grill off but turning the 'nose cone' in either direction doesn't work. i know this'll end up being retardedly easy but we've lost the manual and the obvious isn't working :-)
  • 374 Answers
Hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Posted on Apr 18, 2009
How to remove blades of fan
First, make sure the fan is unplugged. Second, remove the front fan guard. Then to remove the blade you have to loosen the dome like nut nut at the center of the fan. This is a left handed thread so you will need to turn it the opposite direction (clockwise) of a regular nut in order to loosen it.
Aug 05, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
Our fan's blade will barely turn. Can it be fixed?
"Our fan\'s blade will barely turn. Can it be fixed?"
Of course. Usually the front bearing gets dry and gummy. The fan may run after the armature is warm, but it fails to start when it's cold.
Unplug the fan first, right? Then lay the fan flat.
If you can get access to the shaft near the front bearing, just put a few drops of sewing machine oil on the shaft. Let it sit a while, then put the fan in its normal operating position, plug it in and turn it on.
If you can't get close to that area, you'll need to take the grill off, and remove the blades. Then lay the fan flat and squirt some sewing machine oil on the shaft near the front bearing.
The rear bearing is usually OK, while the front one seems to get dry and gummed up.
With the fan flat, run the motor on and off until it starts spinning freely.
Then replace the blades and the grill.
Failing all this, you might find some retired old timer who still does this type of work.
Feb 15, 2011 | Holmes Products HAPF622R Floor / Box Fan
I have a Marvin 1210 window fan with a rotating front grill. The grill has come unscrewed from the fan motor shaft and I can not see how to take the front nose cone apart to get to the screw so I can...
mcdevito75 here, hello ken, I did a fast search and I think www. shop.com can help you out with Marvin air fans, I didn"t find anything on Marvin Air Fans itself. Now about the nose cone covering the nut holding the blade to the fan shaft, most of these nose covers are press fit, see if you can gently pry that nose cover off with a small screwdriver.
Jul 23, 2010 | Marvin 1210 Floor / Box Fan
I have a holmes blizzard fan and need to clean the blade. how do i take the front cover off
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
Jun 30, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Cleaning the fan
There are 4 small screws in the rim between the ribs accessible from the back. Remove the screws and the cover will come off.
Jun 18, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
Holmes HASF-99 10-Inch Velocity Blizzard Stand Fan needs reipair
I downloaded the owners manual from www.usersmanualsite.com but did not see how to undo the grill. However if you go to http://www.holmesproducts.com/Fans.aspx (the fans official site) you should be able to ask them on what to do.
Dec 27, 2007 | Dryers
Heating & Cooling Logo
466 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
