Question about Vtech 2467 Cordless Phone
How can I get a pulse phone to work on a tone system?
  • 37 Answers
Basically, there is no way. The pulse system is what is simarial to the 'old rotary phones, and in today world, the system is dependent on the 'keytones' to establish a connection. Sorry!
Posted on Apr 19, 2009
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
How do I get my crosley wall phone to work on tone setting? it will only work on the pulse setting which is very slow.
The DTMF [Dual Tone Multi Frequency] tone dialing system operates on Direct Current [DC] and is DEPENDENT ON the PROPER POLARITY of the two phone conductor wires!!!!
IF the polarity is reversed, ONLY the PULSE DIALING WILL WORK!!!!!
USUALLY the Tip and Ring wires are colored Red and Green [I think -- it's been a lotta years!!!!!].
HOWEVER, color really doesn't matter as USUALLY ONLY TWO WIRES ARE CONNECTED TO THE PHONE SO REGARDLESS OF COLOR, JUST REVERSE those two wires.
Try reversing the two wires, and then switch the phone to tone dial and try it. That MAY solve the problem!
If that doesn't solve the problem then it's beyond me!!!!!
Good luck!!!!!
Jan 09, 2015 | Crosley Radio Cr55-Bk Classic Wall Phone...
Phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Sep 04, 2009 | Uniden Cordless Telephone
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Vtech 2467 Cordless Phone Logo
82 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
