Question about HP LaserJet 5550 Printer
Error co 59
I have printer 5550 how can i remove error code 59 from my printer
I have printer 5550 error code 59.0 coming so i need hp sevice help
Posted on Jun 14, 2009
  • jameelansari Jun 14, 2009
    pls. give solution how to solve my hp laserjet color 5550 printer 59.0 error coming on the display pannel.
    59.0
Tip
59.co error in hp laserjet 5550 series printers
error because of the sensor located bottom right side of the printer.clean the sensor in an air flow, the printer will be ready
on Sep 16, 2010 | Office Equipment & Supplies
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
I want to know what the problem 59.CO message on my printer Laserjet colour 5550 and how to get it solved
59.XY PRINTER ERROR
(C)= developing disengaging motor rotation error / (0)= no color/black
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 13, 2011 | HP LaserJet 5550 Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
59 C0 error on hp color laserjet 5550
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Dec 17, 2009 | HP LaserJet 5550 Printer
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Feb 27, 2009 | HP LaserJet 5550 Printer
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
Apr 10, 2008 | Office Equipment & Supplies
HP LaserJet 5550 Printer Logo
937 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
