Unusual Power Requirement
Hi! I managed to get my hands on an industrial small form factor motherboard. I have all the components required to get it running... except for power.
It has a female 4 pin (mini/power) din jack, the kind that one often sees on external hard drives as well. What preventing me from using an external HDD adapter is that BOTH of the two live wires (the other two being ground) are 5V. All of the external HDD adapters i've seen have one 5V and one 12V.
So my question is this: would it be safe to get male and female connectors (to make an intermediate hookup) and connect the wires so that both 5V pins on the intermediate draws power off of the single 5V pin on the external HDD adapter? (see lovely ASCII diagram below) The board requires less than 10W and I have some adapters that are 2A and higher for the 5V pin.
||[ - female din on motherboard
<===[ - self-made intermediary with male din on left and female din on right
<===||| - male din on external HDD adapter
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
Should not be a problem, the theory here is Volts * Amps =Watts
5V * 2A = 10w
The alternative is to get a LM7505 ($1 or 2) from radioshack or any electronic supply and regulate the 12v down to 5v. its about 1/2 square IC chip.
Pardon my ASCII:
[_]
input 1.7V - 35V ________| | |_____ +5v (+/- 1%)
Pin 1 Pin 3
will accomodate 1 Amp (1.25 if heat sinked) for the CMOS version, slightly higher for the olde r(less effecient) version
The other pin is ground. OF course you will want to check the specs and pin assignment for the brand you buy, these are typical.
TechieJon
Posted on Jul 20, 2009
Where is used -5v of atx power supply on motherboard asus P4P8X thanks
The amount of current provided at each voltage level is important because of its impact on determining the supply's ability to provide sufficient power for your system. That larger issue is discussed in a separate section. Here are the details on the various voltages provided by today's power supplies:
-12 V: This voltage is used on some types of serial port circuits, whose amplifier circuits require both -12V and +12V. It is not needed on some newer systems, and even on older ones not very much is used, because the serial ports require little power. Most power supplies provide it for compatibility with older hardware, but usually with a current limit of less than 1 A.
-5 V: A now archaic voltage, -5 V was used on some of the earliest PCs for floppy controllers and other circuits used by ISA bus cards. It is usually provided, in small quantity (generally less than 1A), for compatibility with older hardware. Some form factor power supplies such as the SFX no longer bother to supply it (systems using the SFX power supply are intended not to have ISA bus slots).
0 V: Zero volts is the ground of the PC's electrical system, also sometimes called common or (especially in the UK) earth. The ground signals provided by the power supply are used to complete circuits with the other voltages. They provide a plane of reference against which other voltages are measured.
+3.3 V: The newest voltage level provided by modern power supplies, it was introduced with the ATX form factor and is now found on the ATX/NLX, SFX and WTX form factors. It is not found in Baby AT or older form factors. Originally, the lowest regular voltage provided by the power supply was +5 V, which was used to provide power to the CPU, memory, and everything else on the motherboard. Starting with the second generation Pentium chips, Intel went to a reduced 3.3 V voltage, in order to reduce power consumption as the chips got faster. This required motherboard manufacturers to put voltage regulators on their boards to change the +5 V to +3.3 V. The regulators produced a great deal of waste heat and having to do this reduction on the motherboard was very inefficient, so now the power supply provides +3.3 V directly. It is used to run most newer CPUs, as well as some types of system memory, AGP video cards, and other circuits.
+5 V: On older form factor systems (Baby AT and earlier) , this is the voltage used to run the motherboard, the CPU (directly or indirectly) and the vast majority of other components in the system. On newer systems, many of the components, especially the CPU, have migrated to the lower +3.3 V described above, but the motherboard and many of its components still use +5 V.
+12 V: This voltage is used primarily to power disk drive motors. It is also used by fans and other types of cooling devices. It is in most cases not used by the motherboard in a modern PC but is passed on to the system bus slots for any cards that might need it. Of course, drives are connected directly to the power supply through their own connectors
Nov 19, 2016 | Computers & Internet
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
What process should a Business of Removals Industry adopt?
Removals Industry has to adopt following steps;
First They have to mention company number or Quote form, after filling this forum customer comes to know about its move,
Then As per customer requirement provide them removals service,
King Mover Removal
Jan 16, 2013 | Computers & Internet
What is a form factor
The form factor is the size and configuration of a computers motherboard. Common form factors are ATX, and ATX Micro. The size determines the computer case that will accomodate the board. As wel as the power supply required to be used in the configuration.
Oct 11, 2012 | Computers & Internet
NEED SIZE WHAT CU. FT. OF REFRIGERATOR?
It all depends on your requirement the size of the family the number of persons using, the distance to the nearest store , the requirement of the power factor.
Larger fridges will require higher power and must be decided.
Feature like double door and instant ice are based on your requirement
Feb 25, 2011 | Refrigerators
After formating my compaq d510 small form factor the resolution of my computer is bad,looking in the device manager i see that the vga controler is not installed where can i get this drivers?
You can download all of the drivers (not just the display drivers) for your system from the HP web site.
Your specific system's drivers are available on this page.
You will probably benefit from downloading and installing most of the drivers listed on the page linked above. There are a number of drivers that are specific to the D510 small form factor.
Dec 28, 2010 | Compaq System brd w tray for Evo D510 SFF...
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
(9.6 inches is approximately 9 and 9/16ths inches)
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
Updrading power supply of Dell Optiplex GX280 Small Desktop.
Hi there.
No, 400Watts will not affect your computers performance, it just means that you will be able to add more peripheral devices to your PC, for example, an external or internal hard drive or more USB devices.
Make sure you get the power supply from Dell themselves as you will find it difficult to install a standard PSU (power supply unit).
Good luck and thanks for using Fixya!!!
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Graphics card
Desktop Casings are lower enough that can't be closed when inserting Cards like your Graphics card. Change your desktop casing to Tower Casing so you can freely install your Graphics card to the graphics card of your motherboard.
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
