Question about Champion 24 in. UH-150B Built-in Dishwasher
TUW model - not cleaning fully, top sprayer does not spin
My Champion TUW undercounter dishwasher doesn't appear to be getting the job done! The top sprayer spins freely, but is always in the same spot when I open it. I've tried shutting off other feeds from the same 1/2" supply, but it still won't spin during the cycle. Any ideas? Any recommendations for a detergent?
  • 640 Answers
Make sure the wash arm holes arent obstructed and the wash arm seams arent cracked.
Posted on Nov 29, 2007
Kenmore model 587 top rack not cleaning
The belt may have just come off. You may be able to get to it from the back or by removing the very top.
Dec 15, 2012 | Kenmore 16602 / 16604 / 16609 Built-in...
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
Top wond (rack) doesn't clean. Dishes are very dirty at the end of the cycle. However, the bottom rack is fine......please respond asap if possible. Thanking you in advance. Connie
Connie,, make sure in loading the dishwasher you have room for the soap and water to make it to the top rack, (older models) on newer models you have a sprayer just under the rack make sure the sprayers are working fully,, to clean them you can use a hard brush and vinegar,, let stand for 5 minutes and rinse off, also, you can run vinegar ( white) through your machine,, to help clean the jets,, use in place of the soap , then run a couple of times empty to remove and let over odor
May 17, 2011 | Dishwashers
We have a 2007 LG ldf6810ww dishwasher that suddenly is not getting dishes in the upper rack clean, nor is it fully removing the soap from its dispenser. I assume they're related and due to a lack of...
I once had gunk in the rotating sprayer itself that was blocking the dispenser opening properly? I reckon a thorough cleanse with a dishwasher cleaning detergent (the one that takes a super wash to do it) and check the joke a chicken bone was in one of them!!
Aug 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
What would stop the sprayers from spinning freely, A bearing?
Plugged, take em apart and clean all the crud out of them, its alot of work but has to be done.
Apr 22, 2010 | Hobart AM14C-155 Dishwasher
Our dishwasher is type no:575-0, model:665.17369301.dishes r not getting clean properly.
This may help you.
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 22, 2009 | Dishwashers
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Soap stuck in dispenser/dishes not getting clean
try and find a manual to assist you, , but most ot the sprayers have clips that hold them on/in. just be carefull not to break any.
Jan 21, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
My model Num. is TUW - 70
It indicate there is a live ac leakage on the is very dangerous if you don't have any electric knowledge.don't touch it again.switch off the main supply and contact the service technician for help.
Aug 22, 2007 | Champion 24 in. UH-150B Built-in...
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Champion 24 in. UH-150B Built-in Dishwasher Logo
226 people viewed this question
Top Champion Dishwashers Experts
bengsoon Neo
Trevor Turner
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
