I have a tascam 424 MKII Four Track recorder. The Line out RCA Output is very low and distorted. You can only hear it if you increase the volume to maximum. The Individual outputs on the back work fine so there no issue there. I have taken the unit apart and now looking at the line output board. Where do you think the issue is?
  • videoguys Apr 18, 2009
    No not really, i need to increase the volume to maximum in order to hear any audio. the audio is faint and distorted. it doesn't seem like the usual dirty contact switch issue...
  • videoguys May 04, 2009
    Hi Guys, Yes the input Transitors where shot, replaced them all at all it now fine. Thanks for your help.
  • 232 Answers
It sounds to me as if the bias on the output amplifier has changed.This can be caused by a resistor that has changed value or capacitor that has changed the filter range of the output.This really isn't something and end user can repair,there are so many variables that can affect the operation of any electronic circuit.The best option is to have a qualified electronics tech repair this as it will require using an oscilliscope and performing a circuit analysis,and with the cost of four track recorders having come way down it would more than likely be more cost efficient to purchase a new one.I hope this info helps.
Posted on Apr 18, 2009
    Genius:
  • 1,847 Answers
It seems issue with the volume switch.
Do you hear crackling sound while increasing or decreasing the volume using the nob?
let me know ...
K
Just got a Tascam DP-01 and plug my keyboard into input A and assigned it. I clicked the record button for track one . I can hear the output in the headphones and the meter is showing on the Tascam, but...
If the track can be armed for recording, it won't show anything until you arm that track. Otherwise, check to see if you can hear anything on the main output. If so, then it's just the lights, which will not affect functionality.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | Tascam DP01 All-In-One Recording Package...
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Volume low when exporting recording. If I raise
Try inserting a limiter as the last step in the process, this will ensure a better level before mix down.
Mar 29, 2010 | Tascam 2488mkii 24 Track Recording...
Tascam MF-P01 recorder - hearing nothing during play back
Mine also would not play back on any of the channels but would record. The problem was on the lower board, capacitors C105, C205, C305 and C405, all are 220uF, rated at 10V - on a 9V machine! All four went leaky, which meant that the op-amps each were connected to got a bias which drove the output to 8.5V and no output.
I replaced all four capacitors with new ones rated at 25V and it works again!
Dec 09, 2009 | Tascam Starter Pack for 4-Track Cassette...
Tascam 424 MK II, how to bounce tracks?
Here is a link I found that took me to an owners manual for your device.
http://www.scribd.com/doc/264105/TASCAM-424-mkII-Manual
Hope this helps :D
Jun 06, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 424 portastudio mkII power supply
My mistake this is a 424 mkIII not a mkII. Sorry for the typo. Great news is I opened the power supply case and un-soldered the fuse. cleaned it off with tarn-x and behold 3 amps 250 volts. Definatly worth the $1.00 im gonna have to pay for that. As for the **** that was gonna charge me a $100 bucks. There is a reason you are doing that to people. And one day your services will be obsolete.
Apr 28, 2009 | Tascam PS-PS5 Power Supply Power Supply
Sound of the recording after burnt to a cd is very low
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Mar 09, 2009 | Tascam 2488 Portastudio Multitrack...
Okay I have found two solutions here. They may both be the same but the information here is kind of vague so I will post them both. I have found a PS-PS5 power supply as the title suggests. It can be found here: http://www.supermediastore.com/tascam-ps-ps5-power-supply-for-trainer-series.html I have also found a power supply for the Tascam 424 mkii which can be found here: http://cgi.ebay.com/Tascam-PSP424-Replacement-Power-Supply_W0QQitemZ7405614833QQcmdZViewItem Hope this helps!
Jun 10, 2007 | Tascam PS-PS5 Power Supply Power Supply
Tascam mf p-01 portastudio
hi sounds like a worng channel or no output from something check the tape output's for anything if there is sound but bad or low then the tape is the problem if it's good then check that the cable connection is good (connect it to a reciver) then if all is good till the unit: check that you are listening to the right channel check that your output device is good (headphones,speakers) (connect it to a reciver) good luck
Mar 30, 2006 | Lexicon Omega Desktop Computer Recording...
120 people viewed this question
 Grubhead
Grubhead
