Question about ViewSonic LiteBird PJ875 Multimedia Projector
Picture flickers, loses color and lamp turns off.
I bought a used Viewsonic PJ875 projector on ebay. I connected it to my laptop using a 3rd party RGB connector, which did not come with the projector. Everything looked good for about 45 minutes--although things were not as clear as I had hoped. I assumed this was some setting---then the text started becoming pencil thin and the colors faded away. I turned it off and let it rest as I read the manual and set my laptop resolution to 800x600 and shut down my laptop. Then I turned the projector on again and started up my laptop. Looked GREAT at first--but, in 10 minutes, it started flickering, losing color and the lamp turned off. There never was a warning about the lamp--and the settings indicate this is to be displayed. Do I have a dying projector or is this something that can be fixed at a what estimated cost? I have not provided feedback to the ebay seller yet--it was advertised as having been checked out by a technician with everything in good, working condition. I would appreciate your advice ASAP so I can get back to the seller. THANKS!!!
3 Suggested Answers
SOURCE: ViewSonic LiteBird PJ875
If you haven't tried it already, unplug the unit, hold down the power button for 15 seconds, release, then wait about a half hour and try plugging the machine in and powering up again. This may reset the memory and enable your projector to start up normally.
Posted on Mar 31, 2010
heathgr
  • 442 Answers
SOURCE: Our ViewSonic projector was turned on to warm it
have you cleaned out the air filter. Try running in full fan speed operation.
is the unit well ventilated, or in an enclosed space.
Posted on Mar 26, 2011
Viewsonic PJ558D shuts off after a few seconds
Sounds like the ballast board for the lamp stopped working.
Nov 19, 2014 | ViewSonic PJ558D DLP Projector
Viewsonic PD560D no picture green LEDs
there is a colorwheel inside the dlp projector that spins and the light shines through the colored lenses on the wheel, onto a dmd board, and reflected out through the lens. however, if the wheel motor is bad and won't spin, the light won't even turn on. i recommend replacing the colorwheel
Feb 25, 2014 | ViewSonic PJ560D Projector
Green and yellow color with viewsonic pj551 projector
the LCD panels are failing
the price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 11, 2014 | ViewSonic PJ-551 Home Theater Projector:...
Viewsonic pjd6531w projector flickers
Look to the color wheel for your problem. They do wear out.
Dec 13, 2013 | ViewSonic PJD6531W Projector
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp...
blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
have a nice day!
Jerry Lampdeng Limited
Jul 12, 2013 | Epson Replacement Lamp ELPLP30 f EMP-61...
I'm using an acer aspire laptop and a viewsonic projector. projector colors and disply works fine with an xbox bt when i se my laptop, the projector screen goes red. is it the settings on the comp
Make sure you have all drivers and software necessary for the projector installed on your laptop. You can find them on viewsonic's website. Also go to Control Panel>Display>Connect to a Projector and insure all settings are correct. Let me know if you run into problems.
Jun 13, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
HI There, I have just bought a viewsonic pj559d from ebay. Refurbished working with no lamp. I bought a 'JP-UK Genuine Alternative Viewsonic RLC-036-JP Projector Lamp for PJ559D Projector ' and...
A 'genuine ALTERNATIVE', is not a genuine Viewsonic part, but that is unlikely to be the problem. Two choices, take it for professional repair, or send it back to the seller as not working as advertised.
Jul 23, 2017 | VIEWSONIC PJ559D Replacement Projector...
Dec 28, 2009 | ViewSonic LiteBird PJ875 Multimedia...
Viewsonic Projector PJ557D "Screen Flip"
Check the power settings o nthe laptop, go to control panel, power options. see if its set to turn off the screen if theres no activity. I doubt this is your problem but worth a try. Going back to the viewsonic picture means its not getting a signal. So either the cable may be faulty which is less likely, or it is a software problem. Does the screen flicker on the laptop when doing the same thing (if the projector is not connected)?
Jun 12, 2009 | ViewSonic Lenovo Viewsonic PJ557D Portable...
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
ViewSonic LiteBird PJ875 Multimedia Projector Logo
129 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
