Question about Motorola Mobility V710
I have a Motorola V710, it will not power on but the screen blinks when plugged in to charge, what's wrong?
  • bill809 Apr 18, 2009
    The battery was just replaced to no avail, it does the same blinking as it did before I replaced the battery.
  • 221 Answers
The batery may not be holding a charge anymore, try removing the battery and clean the contact's, if that do'es not work the battery may need to be replaced.
Posted on Apr 18, 2009
2 Suggested Answers
jocoolguy
  • 1912 Answers
SOURCE: V710 Motorola will not power on but screen blinds off & on plg in
I think there is some problem @ your battery. Change the battery & check whether the screen works or not if it ask for unlock code you can get the code from motorola code
Posted on May 22, 2009
How do you turn on a motorola v710 after is has charged
push green button and hold on for a couple of seconds.
Jan 03, 2015 | Motorola Mobility V710
Drivers for phone
www.motorola.com under support for your phone would have the driver and software, thanks and please rate my solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | Motorola Mobility OEM Bluetooth USB PC...
Apr 18, 2009 | Motorola Mobility V710
Won't connect to service
Possible easy solution: Remove battery, put back in phone, power up try again.
If that doesn't work: Phone may need settings rewritten to phone, contact your carrier.
Worst case: Phone is toast, if its a 710 its probably a little older, as far as phones go.
Aug 07, 2008 | Motorola Mobility V710
Motorola v710 cell phone
Is the battery lithium -ion? If not, you have an older generation of battery.
Having mentioned that, some batteries need an introductory "conditioning period". Continue your excercise of charging and draining (dont drain too too low) and hopefully you will start seeing some decent longer lasting charges.
Hope that helps!
Feb 08, 2008 | Sony Ericsson W200i Cellular Phone
New Motorola V710 Cell phone, says it has cricket service
check your screen if there is a small number 2 in the corner or up the top somewhere then this shows you have your phone set on line two for call waiting
go to call settings in your menu and change phone line in use back to line 1
Oct 25, 2007 | Motorola Mobility V710
Motorola v710
You probably damaged the flex cable. You'll probably want to find a repair facility and get quoted a price. The part should be approximately 20 dollars. If you do want to try replacing it yourself it is a pretty rough phone to assembly/disassemble so be careful. Good luck.
Sep 09, 2007 | Motorola Mobility V710
Unable to send
YOU HAVE THE WRONG SETRVICE CENTRE NUMBER IN YOU NEED TO RING YOU PROVIDER AND GET THEM TO SEND SETTINGS OR THERE GUIDE YOU THRO IT OR IF YOU HAVE THE SERVICE CCENTRE NUMBER GO INTO STTINGS THEN TXT MESSAGES THEN CENTRE NUMBER DELETE AND PUT NEW ONE IN AND SAVE THEN IT SHOULD WORK
Apr 11, 2007 | Motorola Mobility V710
Motorola V710 won't charge
While not a fix for this problem, what I have found to work nearly every time is to set something slightly heavy on the charger prong where it enters the phone. Turning it over and resting the prong on a book also allows it to make the necessary contact. It has lasted me for two years; one year charging just like that.
Dec 16, 2006 | Motorola Mobility V710
Doesn't turn on!!
you need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Jun 24, 2006 | Motorola Mobility V710
Motorola Mobility V710 Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
