Question about Canon Snappy EL Point and Shoot Camera
How to load film in canon snappy el - Canon Snappy EL Point and Shoot Camera
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
Canon 3055 number of pages per catridge
arbitrary at best. all depends on amount of ink. started cart will due 50-100. full cart maybe 300
Aug 03, 2014 | Canon Cannon Fully Automatic 35mm Film...
Loading film in canon tlb
Follow the illustrated instructions beginning on page 27 of the manual.
Sep 27, 2012 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Cual es el fusor de una copiadora Image Runner 1670f
Canon Ir 1670 doesn't use fusor; it uses fixing film; part number is FM5-0992-000 @ 120V this issue happens frequently in these machines.
Roger
Dec 06, 2011 | Canon ImageRUNNER 1670F Copier
How to load film
http://www.usa.canon.com/app/pdf/compact_film/Sure_Shot_Z135_manual.pdf
The link above will take you to a .PDF that is an owners manual for the Canon Sure Shot Z135
On page 14 it lists how to load film into the camera.
1. Slide the back cover downwards
2. Insert the film
- Make sure the film is positioned above the film guide
3. Pull the film tip across until it reaches the film tip marker
- Make sure the film is flat
4. Close the back cover
5. Turn the dial to (auto)
(Turn the power on)
the camera will automatically advance the film to the first frame.
6. "1" should be displayed on the frame counter
If this show zero there has been an issue, make sure you are using the proper film for the camera
Aug 24, 2011 | Canon Sure Shot Z135 35mm Point and Shoot...
What is this camera worth?
Hello mayb.... Here is a link here you can purchase this camera for $4.95 plus $6.00 shipping. Joe
Thanks for choosing Fixya!
Jan 04, 2011 | Canon Snappy QT Date 35mm Point and Shoot...
ERROR E007- CANON IR2020, COMO SOLUCIONO??
You need a new fusing film unit or a new fusing unit
Jan 23, 2010 | Canon imageRUNNER 8500 Copier
Film won't load on Minolta 400si Maxxum Camera
My daughter took the camera to her photography teacher he was able to load the film by wrapping more film around the roller. It's not as easy to load as my Canon. I thought we had put plenty of film around it already. Oh well, it's working anyway.
Feb 18, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Canon Snappy EL Point and Shoot Camera Logo
181 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
