Question about Kenmore Elite 45986 Front Load Washer
1999 Ford Contour - How do you get the alternator out!!!
My husband is beating his head against a wall, the alternator is bad on our 1999 Ford contour and he can get to it to replace it. we do not have a lift liek they have in garages and he has taken the tire off but you can't get the wrench aroung the screws because they come in from the other side and theri is no space.
  • mrip May 24, 2008
    the battery light is staying on and sometimes it bucks. is it the alternator?
2.5L Engines
  1. Disconnect the negative battery cable.
  2. Release the drive belt tensioner and remove the drive belt from around the alternator.
  3. Raise and support the vehicle.
  4. Remove the passenger side front wheel and fender well splash guard.
  5. Disconnect the passenger side outer tie rod end from the spindle. Refer to the Suspension & Steering Section.
  6. Remove the exhaust system Y-pipe.
  7. Unplug the connectors and remove the cables from the alternator.
  8. Remove the alternator brace retaining bolts and the brace from the vehicle.
  9. Remove the passenger side halfshaft, as outlined in the Drive Train Section
  10. Remove the alternator mounting bolts and remove the alternator from the passenger side fenderwell.
Posted on Oct 25, 2007
Need to find the crankshaft sensor on a 1999 Ford Contour 2.0
https://www.google.com/search?q=crankshaft+sensor+location+on+1999+ford+contour+2.0L&espv=2&biw=1366&bih=667&tbm=isch&tbo=u&source=univ&sa=X&ei=qV5VVOChJ4mBygSqnoDQAw&ved=0CB0QsAQ
Nov 01, 2014 | 1999 Ford Contour
98 ford contour wiring diagram
When you tell us "wiring diagram", is for one specific circuit or you are refer to the firing order?
Apr 13, 2010 | 1998 Ford Contour
1999 contour SVT: Where is the alternator ?
Under the passenger side of the motor near the back..Good luck its a pain in the neck to change!!
Apr 06, 2010 | 1999 Ford Contour
I need a fuse diagram for my 1999 ford contour specifically which fuse is for the alternator
have you checked your owners Manuel if all else fails you may check your local library for a book on the specific vehicle in question
Sep 15, 2009 | 1999 Ford Contour
1997 ford contour battery light on & off but mostly on
Check alternator/drive belt, & Have battery & charging system (alternator ) checked. Make sure connections at battery are clean & tight too. If you have a multimeter, check voltage before you start & after & see what it reads & let us know.
Apr 23, 2009 | 1997 Ford Contour
Fuel injector cut off switch for 1999 ford contour se
Try looking by your left foot, while sitting in the drivers seat.
Mar 14, 2009 | 1999 Ford Contour
Car goes Dead
Normal charging volts are about 14.5, 13 volts is too low. The spec from Ford is 14.1 to 14.7. Broken wires or a bad connection are common.,
Jan 27, 2009 | 1998 Ford Contour
My 1999 Ford Contour has a variable valve timing/camshaft which I don't know how to properly time. Also how do you remove the cam belt sprocket so that the head can be removed. It looks like it is held...
the crank notch should be up and the two square lobes have to be pointing up square with engine i used welders vise grips yes the cam bolts are torx
Aug 22, 2008 | 1999 Ford Contour
How to time up a 1999 ford contour
how to change a timing belt
Jun 27, 2008 | 1999 Ford Contour
Kenmore Elite 45986 Front Load Washer Logo
2,257 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
