Question about Biostar M7VKS Motherboard
Can i use usb keybord & mouse in this jusb2 port
  • 298 Answers
As long as it fits, its perfectly fine
Posted on Apr 19, 2009
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
Como conectar los Jumper JUSB1/JUSB2
USB pinout;
Motherboard - MSI H55MP31,
http://www.msi.com/product/mb/H55M-P31.html
Hover your mouse cursor on Download.
(Overview, Specifications, DOWNLOAD, Support, Where to Buy)
In the drop down list click on - Manual
Left-click on the Blue, (Azul), -
M7636v1.0_Euro.zip
(Multi-Language - User Manual - Motherboard)
Front USB Connector: JUSB1 / JUSB2 / JUSB3
Shows the pinout.
Regards,
joecoolvette
Apr 18, 2012 | MSI H55MP31 LGA 1156 Intel H55 Micro ATX...
Lost my set up directions...can't connect mouse or keybord...they only have usb ends.
Hi ebdaly...
Most all keyboards and mouse connections now are usb connected.
Just plug the usb from the keyboard or mouse into a usb port on the computer and you should be good to go.
The drivers for the keyboard and mouse are built in to your computer if you have XP/Vista/7,so they are "plug and play" items
If it does not work on your computer then you will have to have an adapter like the one show below for the mouse and keyboard, you can find these at Walmart,Staples,OfficeDepot,this one is from ebay.
Please take time to rate me
http://www.ebay.com/itm/USB-Male-PS2-PS-2-Female-Keyboard-MOUSE-Adapter-/160645167578?pt=LH_DefaultDomain_0&hash=item256732b9da
Aug 31, 2011 | Computers & Internet
Can I replace just my HP wireless mouse or do I have to replace keybord also?
Yes you can replace each one seperately because both are connected by using two different usb ports
Apr 06, 2010 | HP Wireless Optical Mouse
My mouse and keybord does not work, also the red light on the front of my computer stays on
mouse and keyboard may be plugged into the wrong ports... crossed. or ur ps2 card could be bad... easy fix ... purchase a usb mose and keyboard.
Feb 02, 2010 | ZT Group Cisnet PC Desktop
Problem com1 ps2 mous and keybord
Well firstly I'd try another usb port...
Secondly there are loads of usb-ps2 connectors, theyre very cheap, just go to any computer store and buy 2, see if that helps.
I hope this solves your problem,
Yannick
Feb 18, 2009 | MSI : MS-7061-020...
The keyboard does!t work
remove the connections and reinsert them also uninstall and then connect and reinstall keyboard.
Jan 12, 2009 | Adesso Gift Idea Under $50: Win-Touch...
KVM converter
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
Apr 09, 2008 | Computers & Internet
Computer will not see wireless keybroad and mouse in usb port on turn on pc
hi friend
u have to reset ur mouse & keybord then its dectec
Mar 31, 2008 | Computers & Internet
HELLO
is your mouse and keyboard plugged into a PS2 connector http://en.wikipedia.org/wiki/Image:Ps-2-ports.jpg
look inside of your case and see if any capacitors are buldging on your motherboard the tops of the capacitors should be level/flat if they're ok, sounds like they are going, look for brown rusty color also around tops of capacitors, might be your outputs are going. If you have your mouse and keyboard plugged into ps2 ports try a USB Mouse and keyboard, borrow one first or buy a usb laser mouse for $12 worth a try even if your ps2 ports are blown, use the usb ports for mouse/keys ;)
Jan 10, 2008 | Dell Dimension 4600 PC Desktop
Biostar M7VKS Motherboard Logo
90 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
