Question about Dell Vostro 1000 Notebook
Vostro 1000 black screen an i can hear it running, but can see..
I have a dell vostro 1000 I just recently have more memory put into it. now when I turn it on the green a button with a lock on the keyboard blinks, an the screen is completely black. what does this mean? How can I fix it?
  • Cherry143 May 06, 2009
    Oh my gosh, I just had the same problem I will try to do what bajaman said.
    Okay, I just got mine to power back on with a working screen. I have been powering it off and on for a while this morning several times. And I just held down the power button for a few seconds until it powered off, then I powered it back on, and the screen started to work. My comp has been doing this for the past 3 days. I have no idea what I do, but I just kept on powering off and on. Make sure to hold it down for at least 5 seconds. Sorry can't tell you exactly why and how this is happening. Dell just sent us broken down laptops, as always. This is my second laptop from them, I have an Inspiron 6000 and this Vostro. Both have been big problems. Good luck.
    Problem Solver:
  • 14 Answers
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Posted on Apr 18, 2009
Remove one of the memory modules. start the system. if nothing changed then put the memory module back and remove the other module. start the system. this worked for me?
Posted on May 14, 2009
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
I updated the bios on the dell vostro 1000 and it wouldn't start. The power light stays on and you can hear the fan. This is followed by a long beep and 2 short beeps while the screen stays black.
Hi alkeith...
Turn on the computer while tapping F8, this will take you into the Safe Mode.
While your in the Safe Mode you can do a system restore.
Restore your computer back to an earlier time when it was working before you installed the bios change.
Left click on Start>All Programs>Accessories>System Tools>System Restore.
This should solve your problem.
Please take time to rate me
Aug 05, 2011 | Dell Vostro 1000 Laptop Computer (AMD...
I have a dell vostro 1000 and when, i turned it on it seems to be runnig, but gives a fully black screen...
ok.Tell me more about this problem.
Have you tried to connect an external monitor to the laptop?
Nov 23, 2010 | Dell Vostro 1000 Laptop
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dell vostro 1000 will not turn on
remove the memory cards and wipe the golden ends with an erraser and than put them back in and issue will be resolved ... if that doesnt help... if there are more than one card than remove them again and reseat one card at a time and you will find the culprit and you have to change it and in case of one card you have to change that
Feb 09, 2009 | Dell Vostro 1000 Notebook
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Dell Vostro 1000 Notebook Logo
2,796 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
