Drivers I changed from Vista to XP pro as OS in my system now I don't have the drivers to get my PC perform at its best.
  • 432 Answers
Can you clarify what computer you have ( make and model ) and what drivers you need.
If you at least get the network card driver for the computer you can then use that computer to connect to the internet ( assuming your using broadband ) otherwise you will need the modem drivers for the dialup modem.
Posted on Apr 18, 2009
Changing OS from windows vista to xp
You can install xp on a vista laptop, you will need an xp install cd and you will need to backup your data (it will be erased in the downgrade process). As for the drivers, go to your laptops manufactures site. They will have a support section for your laptop model where you can see if there are drivers for xp. If you have the hardware that will support windows 7, I would go with that. Xp is slow and no longer supported by Microsoft as of April 2014, which poses a security risk. Windows 7 will be supported for a while and is faster and more stable than xp or vista.
Nov 30, 2013 | Compaq Presario C700T Notebook
I changed my vista to xp from that time sound software is not support in my system
Actually the audio driver you used in Vista OS is not supported by the XP OS. So try to find audio driver for your motherboard that is fully compatible with XP.
Dec 25, 2010 | Computers & Internet
I installed window professional my model Compaq presario c500 i don' hear the sound give solution to download sound driver
try this website there is the option for Xp an vista, download driver, save it and then install it.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3413016#N678
select your OS it is the same driver for Xp home, pro and the same for Vista home, pro, ultimate
if it works for you don't forget to rate me
May 21, 2010 | HP Compaq Presario C500t Notebook
Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
Sep 07, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Change operating system
You can keep both Vista and XP. Below is the way to install XP, after Vista was already installed... creating a dual boot. First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive. Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive. Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component. Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to. And now you should be able to dual boot between Vista and a previous OS. Thank you! Sabharish
Jun 15, 2009 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
I Want to change my vista os to window xp for my laptop Hp Pavillion dv4 1240 tx.
yes. you can change vista os to window xp. but before the installation make sure does hp provide the driver all of those which your are going to use. for the driver detail log on www.hp.com.
once you make sure about the drivers , then arrange the XP bootable cd . and now try to install xp on your system.
Mar 24, 2009 | HP dc7800 Business Desktop USDT Alternate...
Dr. offoce in Anza CA, bought a desktop computer for his office and the O.S. is Vista, changing the system to XP Pro, need drivers for his emachine s/n 82300811290,T5274 for his, motherboard,modem,sound...
eMachines only released this model for Vista so the only drivers they have on their site is for Vista.
A little research revealed that they used the ECS (Elitegroup) 945GCT-M3 motherboard to build this system. Elitegroup has XP drivers for this board and you can download them here:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=719&CategoryID=1&DetailName=Driver&MenuID=44&LanID=9
Oct 11, 2008 | Computers & Internet
ACER Laptop with Vista OS
My problems is Microsoft works. I thought when I bought this computer from Best Buy that it wasn't trial one. It keeps telling me to put the # in. I can't seem to find the # they one. I have used without the #. But it dosen't let me do everything with out it.
Apr 30, 2008 | Microsoft Office Professional 2007 Full...
Need RAID driver for toshiba Satellite A205 S5804 changing OS from Vista to XP...please help
the only EASLY way is if you can download Vision Xp : HERE and Burn it ino cd and format pc with this OS.THis Os have all raid driver!
Best Regard's
Beni
Apr 04, 2008 | Toshiba Satellite A205-S4617 Notebook
V3424au presario notebook update
This is possible but will take some patience. Install Windows XP & Service Pack 2 Then check what drivers are NOT installed by going to device manager. Then go the the Compaq page that lists the drivers for Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=uk&dlc=en&product=3446906&lang=en Make a note of the name/model of these drivers and search for the XP equivelent usually by visitng the device manufacturers website. Im sorry this is complicated and long winded but its the only way.
Aug 27, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
