Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WT741
Showing a F-03 fault code, will not drain turn off or do anything. Is there a solution other than calling out the engineer?
  • Anonymous Aug 12, 2008
    have turned machine off at the mains. also tried an empty programme. also tried to run the machine on different programmes
  • 209 Answers
If it wont drain check the pump for any blockages and working condition
Posted on Sep 20, 2007
SOURCE:
Hotpoint ultima wt741 f10 fault code
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked / blocked.
Apr 10, 2012 | Hotpoint Washing Machines
Hotpoint ultima WT741 washing machine not working flashing F-03
F03 - Wash thermistor open/short circuit need a engineer out to fix it. hope this helps.
Mar 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My washing maching wt741 keeps flashing f-12 could u pls tell me the problem, thank you
Hi.
F12 indicates 2 or 3 differant faults.
Try these first.
Press and hold start/ cancel button for at least 3 seconds, and see if jt works.
Make sure hot and cold water taps are turned on and that you are getting water to the m/c.
Select a drain prog, and see if it pumps out o/k.
If all these do not solve problem, then you have a communication error between boards, this entails calling an engineer out.
If it is under 5 years old then you should be covered by the Hotpoint 5 year part guarantee.
Plz rate my solution .Thanks.
Dec 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Wt741
not sure if this is repairable but wonderedif anyone else has had the same problem,my wf860 keeps flashing f-03.
Oct 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Have code f-11 can you tell me what it means.hotpoint ultima wt741 king capacity plus
In the back of the manual there should be a list of fault codes and remedies. if you dont have the manual you may find it online or call the retailer and they should help.
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Hi.
F05 meqans that pressure switch is jammed.
You will neeed to call an engineer.
Jun 12, 2008 | Hotpoint WMA35 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
483 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
