I BOUGHT A.C LG AS-H366NMM2 34000 BTU WITH 3/4 inch gas pipe but at my house thre is 5/8 inch pipe gas please advice me if it is necessery to change the pipe gas at my house to 3/4 inch
  • emmanuel10 Apr 18, 2009
    It seems my question was not understood:my line is smaller (5/8) than the air conditioner unit line (3/4), hence, my line is not larger than the one that is being called to use- it is the contrary. So, is t possible to install it this way; if yes, isn't it going to be more noisy that it should be orgoing to cause some problems?
    Thanks a lot for your quick and professional answer. It answers the issue and I am now able to handle the installation with my technician.
  • 659 Answers
No, you are fine as long as your line is larger than what it is being called to use.
Posted on Apr 18, 2009
  • 1 more comment
  • Donni Steen Apr 18, 2009
    It depends on what type of copper you are referring to. Are you using refrigerant copper, otherwise known as annealed copper? Or are you referring to nominal copper? Ok, then to answer your question if your inside diameter is smaller than the inside diameter of what it is being called to use, then you MUST replace it. Refrigerant copper is sized using outside diameter. 7/8 inch annealed tubing is considered 3/4" nominal and so on.
    I forgot to add this to the post. The unit will not be more noisey. The less effort on the part of the compressor to pull the refrigerant to the condenser will make it use less energy. When the refrigerant lines are too small for it, it starves the condenser unit, and the coil causing the compressor to work harder and pull higher amps. It is fine to use larger piping but you can not use smaller without having some issues that later can void a warranty because the proper copper sizing wasn't used.
    Your welcome! Have a great weekend and hope the install goes well!
What size fresh air vent do I need in a boiler room with a gas boiler and gas hot water heater with about 220,000 btu combined
I suggest that you run a duct that is 3 inches larger than the furnace duct . and you should run it down close to the floor and aim it in the direction of the furnace. this will trap warm air above the vent and supply an adequate supply of air for combustion. also make sure you have insulated any pipes in the furnace room that carry water or steam you want heat where you live, not going up the chimney.
Aug 02, 2014 | Water Heaters
Bought a Rinnai Tankless water heater, propane hookup is 3/4 inch and our gas line where the water heater goes is 1/2 inch. also the regulator from the propane tank is for a lower flo gas flo, for our...
Sure is. You simply need to purchase a to 3/4" to 1/2" Male to female reducer. You didn't mention if your current gas piping is flexible copper, rigid black iron pipe or flexible stainless steel. In any event, get the one that matches your current gas piping. If all of your other gas appliances require an individual regulator, then you'll need one for the tankless water heater. If in doubt, contact your propane provider.
Hope this helped answer your question and provide a solution.
Mar 09, 2011 | Heating & Cooling
The dryer does not dry, it yet runs but the heat is not effective. Further more please tell us any advice what to do to help the problem
first check your house venting for a clog. do this test. take the vent pipe off the dryer, dry a load and if the load dries between 45 to 60 minutes then you have a clog in the house venting.
Feb 12, 2011 | LG DLG5932W Gas Dryer
Is a model py1pnb036090abaa Payne gas pack large enoug
3 ton cooling capacity 90,000 btu heat capacity. In Vermont it would be enough if the home was a 4 or 5 star home. Remember it is only 80% efficient so you will only net 72,000 btu output.
Mar 09, 2010 | Heating & Cooling
EMPIRE MDL 215 VENTID NOT HOT ENOUGH
Sal,
the gas pressure test should be done. Propane should have an outlet(heater side of the regulator)of 7 inches of water column. the inlet side has to be higher than that to supply it the proper pressure. Also the heater should have been converted to LP with proper orfices and springs
Dec 13, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
I HAVE A PENTAIR MASTERTEMP 400000 BTU NAT GAS UNIT, NEW ON NEW POOL. IT WONT LIGHT, THE PLUMBERS RAN 1 INCH LINE TO UNIT AND STEPPED IT DOWN TO 3/4 3 FEET FROM UNIT, THERE IS ALSO A 3/4 INCH REGULATOR,...
Generally speaking, too small a gas line will not inhibit the heater from lighting; it just won't burn efficiently and you will likely shorten overall heater life due to burner corrosion and soot buildup on the heat exchanger. Unless the total run of pipe to the heater is under 20' the pipe should have been 1-1/4" or larger, depending on what type of pipe was used.
That said, you should probably contact Pentair to arrange for a warranty service call to examine why the heater is not lighting. If the tech sites installation issues, be sure to get it in writing so you can go back to the plumbers for corrective action.
Contact Pentair. Select service providers and heaters and you should find someone local...
In case you do not have it, here is your owner's manual.
Oct 11, 2009 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Rinnai Tankless won't stay on
how far is the tankless from the gas meter? error code 12 means it doesn't have enough gas running to it. is the 3/4 flex true 3/4 or is it 1/2 with 3/4 threads. have you checked your BTU load on your house to make sure your 1'' pipe can handle everything else you have on the house? sounds like to me you dont have the right amount of gas to the unit.
Sep 29, 2009 | Rinnai Webstone The isolator EXP tankless...
Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Dec 01, 2008 | Dayton Heating & Cooling
Gas line BSU"s
3/4 inch pipe is first choice but 1/2 inch pipe will work.
Aug 21, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
