Question about Microsoft Xbox 360 Console
New Xbox 360 disk drive doesn't play games
I bought a new xbox 360 drive and installed it myself, now the game don't work on it. it says i need to install the disk into an xbox 360 system, then a bunch of chinese writing.
  • 20 more comments
  • Anonymous Dec 20, 2007
    I have the same problem. What do you do if you no longer have the original drive?
  • boots350 May 23, 2008
    My console is doing the same thing, but the dvd drive has never been changed. I can say for sure that the drive is piled up, because it stays on the guide, and tells me to open the disc tray as if there was no disc in the drive. The drive doesn't really rev up in rpm like it should, just a low hum slash vibration. In one of maybe twenty attempts the disc will start to rev up, and then I will get to the screen where it tells me to play in a 360.
  • Anonymous May 31, 2008
    hard
  • CanadianBaco Sep 18, 2008
    I just bought my 360 and it says please insert disc into an Xbox 360 console, but when i put in this demo disc and it works fine, but my halo 3 doesn't work
  • drewboo96 Oct 27, 2008
    i put a disc in and it says unplayable disc or to play this disc put it in an x box 360 console.
  • gweedofireha Dec 28, 2008
    im having an issue with mortal combat vs dc comics.its my only game that wont start...anyone??
  • Anonymous Jan 19, 2009
    it will read the game as a dvd, when i select play dvd it says to place this disc into a xbox 360 console! Im trying so hard to find a fix for this problem
  • Wildman26x Feb 16, 2009
    mine will also not play 360 games only. i can play xbox games and dvds. it started with a sticky tray then would not play 360 games. i fixed the sticky tray with a new o-ring. then cleaned the laser and put in 360 game and still says put in 360 disk does not rev up like before this IS a original drive
  • Anonymous Feb 28, 2009
    I have bought more than one cd drive one is hitachi and the other is philips and my xbox 360 says the same thing..... what do i do?
  • chopper16 Mar 11, 2009
    everytime i put inn a game into the 360 it always says to play this game insert into a xbox console. how do i get that fixed what do i do.
  • leolynn Mar 18, 2009
  • Anonymous Mar 25, 2009
    I removed my 360 disk drive to repair it, the drawer was sticking, now when I have put it back together it refuses to play the games but plays dvd's same as yours. Im on the hunt for solution now. 25 March 2009
  • Anonymous Mar 29, 2009
    Mine plays dvds but wont paly 360 games too and i cant find a solution please help!!!
  • Anonymous Apr 09, 2009
    When i install games to my xbox Hardrive it says that i need the disk to play it even when i installed it.
  • fostermark95 Apr 12, 2009
    when i turn on the consoul the xbox shows the start up bit then it goes staight to a page which says ''can't find the update disc,please reinstall the disc''' ????????? i've tried putting the same game back in but still no joy can you shed some light ///?
  • Hydrojoe Apr 22, 2009
    My Hitachi Drive on my 360 Finally stopped working, So i went online and bought a BenQ replacement drive, Installed it, Now will play dvds but not any 360 games....... whats wrong???
  • Anonymous Apr 26, 2009
    it duse that on myn the wrighting and i got a new one so cant realy help u sry
  • I Like Cake May 25, 2009
    My profile for Live in Xbox 360 does not load but my other one does. You see it worked fine in my live and then a little while later i turned it on but it wouldnt load PLEASSSSEEEE Help?
  • wow cd key May 11, 2010
    Solution Link:http://xboxinstructions.blogspot.com/
  • wowgold May 11, 2010
    Best Solution link is here:http://solvexbox360.blogspot.com/
  • dulaki May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com
  • Robert Allen
    Robert Allen May 11, 2010
    are you taking about the external drive or a replacement internal drive?
  • 28 Answers
Well my friend thats because each xbox 360 drive is unique for each console so it only works on the original console, to solve this you have to flash the firmware from the old drive and put it the new one, there are many sites explaining it just google it.
Posted on Oct 03, 2007
Ok, traaav the problem with your drive is that you need to flash it, this happens when you switch out the drive of your console for another one (obviously). You see, each xbox 360's motherboard comes with it's own unique key and each key is married to the dvd drive, without this key your new dvd drive won't work. If you replaced the old drive with a new one of the same model all you need to do is open the old dvd drive, remove the circuit board and replace it in the new one. you can follow this link for visual instructions on how to do that http://www.youtube.com/watch?v=G5hdC2kx4-Y ....... now if you replaced it with a different model of drive say a hitachi for a samsung you will need to flash the new drive, which really isn't for novices but with proper instructions I'm sure you can get it done, follow this tutorial, you'll have to register on the site first to see the tutorial, don't worry it's free to register..http://xbox360iso.com/showthread.php?t=95039 . I hope this helps your little problem.
Posted on Jan 03, 2010
Ok all u gotta do is whip out ur fat ****, bang it on each corner of the xbox and *** in between the harddrive and the xbox and the put em together then THERE YA GO!
Posted on Jul 10, 2009
First solution is to NOT listen to XxXboxGuyxX. There are at least 3 ways to fix this problem and this guy, with his weak vocabulary seems to be the f#$%in idiot. Look at solution #4!!! Who is the idiot now?!?!?
Posted on Feb 01, 2009
I read on a site that after you install a new disk drive that you also need to install a application. on this site i read that on you simply have to put that file on a usb drive (Flash-drive or thumb drive). then install the app after you installed the hardware. im not to sure what site it was on but try to google it. try keywords like. Steps on installing xbox360 disk drives or software hacks for new disk drives.
Posted on Feb 10, 2009
Im not positive but i think you have either purchased the wrong type of dvd drive for your 360,or u have purchased a used one.they are keyed to the mother board of each 360 so you cant swap them with other used drives without flashing them.if you look on the bottom of the dvd assembly there is a little mother board,with a chip on it if you would have swapped that with the one on the new dvd rom before turning power on you should have been fine.im working on how to fix the problem.
good luck with your 360 : )
Posted on Mar 27, 2009
All you need to do is flash the drive to your 360
if you have any questions call 614-529-1726
Posted on Mar 24, 2009
  • 3 Answers
Get a new disk drive
Posted on Jul 17, 2009
    Problem Solver:
  • 12 Answers
If your xbox keeps saying insert disk into an xbox360 there is no known way of fixing it! ive changed the circuit board in drive, i have attempted flashing it and i have put a new drive in and changed the serial key to the one from the existing drive,it still says the same thing,i think the problem is a chip on the mobo.the only way to solve it (sorry for saying this) is to send your xbox off to microsoft.its that or you can have a posh dvd/cd player,but you cant play no games on it.
Posted on Mar 14, 2009
If ya disk drive will not play games and u put in a new ur a fuckin idiot every xbox has its own codes and there for it will not fuckin work DUH HHH ... but for the guy thats XboX says open tray is the reen light flashing as if is were trying toopen If So that mean's it has Shrted out or A Cable Has Come Loose
Posted on Sep 09, 2008
I jes bought a ts-h9 something is a tosobai samsung... anit wont let play my games.... but dvd works fine... and when it load my games it say plz play xbox 360 cosuln games and also writen in japanesse too...
Posted on Feb 08, 2011
Dont think ist a disk drive problem because i changed disk drives in mine to on that i knew worked and still got the say thing think is a software problem
Posted on Oct 22, 2010
Hey everyone,follow #7 solution,tried it out to with broen xbox and it work,just switc out the memory chip on t disk drive(it's the chip board that plugs into your 360.
Posted on Feb 14, 2009
Or if you bought the same diskdrive, you can just switch the chips inside the drives, you put your old one in the new d-d
Posted on Aug 24, 2008
Buy a new one
Posted on Sep 17, 2008
Hey what i did was i got myself a lens cleaning disk from my local shop. the instructions usually tell you to put one drop on each brush. honestly that sucks! i put about 4-5 drops of their solution on each brush then i quickly put it into my 360 and played the disk, it did its job and my games once again work perfectly. i think this only works if you have a dirty lens though. so good luck everyone.
Posted on Apr 18, 2010
2 Suggested Answers
  • 839 Answers
SOURCE: i bought a new xbox
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console........
Click here to download repair guide
Posted on Dec 24, 2010
Tried to play new game, says not enough memory space. I deleted everything and still wont play, help!
You may have an old series console version of the Xbox 360 that only has either 256MB or 512MB of internal memory. You may also have a new series console version of the Xbox 360 that only has 4GB or data storage. For multi-disk games that install one or more disks, you need, at minimum, a 20GB hard drive installed in your console. You will need to invest in a hard drive for your Xbox 360.
Mar 22, 2014 | Microsoft Xbox 360 Console
How to play xbox games on a new xbox360 slim 4gb
I am assuming you are referring to playing original Xbox games on your new 360. Halo was the only game from the box that you can play directly without needing to download the patch to play but supposed newer systems have the capability to play more directly out of the box.
Other backwards compatable games can be played but you will need a samll patch for each game. The game if playable will automatically attepmt to download the patch from xbox live. So you will need to have your Xbox 360 conected to live or have a patch disk. (which is available via the Xbox Magazine disk or can be downloaded online and burned to a disk)
Here is a link for Xbox games that are playable on the 360: http://en.wikipedia.org/wiki/List_of_Xbox_games_compatible_with_Xbox_360
"You can play some original Xbox games on your Xbox 360 console, if you have an Xbox 360 Hard Drive and the latest console software.
Information about how to update your console software is available on our Xbox support website:
support.xbox.com/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx "
Jul 30, 2011 | Microsoft Xbox 360 Console
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked...
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 wont play any disk keeps saying no disk
Try cleaning the disk, if that doesn't work, try another disk, if that doesn't work, then turn the xbox off, take the hard drive out, put it back in, then try playing the game again.
May 28, 2011 | Sony Video Game Consoles & Games
Bought a 250gb hard drive to put into new x box slim console to play an original x box game....still will not play or recognize the game (SNK vs CAPCOM) what am I missing??? Do I need a disk to download???
Hi there, not all original Xbox games can be played on the Xbox 360 and Xbox 360 Slim, I came across the same problem myself. I have checked the compatible games lists and cannot find the game you mention on any of them so I am presuming that this game unfortunately will not play on the Xbox 360.
Sorry to be the bearer of bad news
Apr 20, 2011 | Video Game Consoles & Games
I bought a new xbox 360 driver circuit board and installed it myself, now the game don't work on it. it says i need to install the disk into an xbox 360 system, then a bunch of chinese writing help
Dec 24, 2010 | Microsoft Xbox 360 Console
My son saved money and bought a Xbox 360 Arcade. He did not realize that he could not play his xbox games on his new system. Is there an upgrade to allow old xbox games to be played on on the xbox 360
Some game are compatible with the new xbox 360. They are called backwards compatible and you do need to flash upgrade the OS on the new xbox 360 system.
You need to go to the xbox website and go to support and download the flash update then burn it to disk and put it on the xbox to update the software. Again not all old games are compatible with the new xbox system. If your buying used games like I do make sure it says bc next to the title before buying them.
Here is the link to the upgrade
http://www.xbox.com/en-US/games/backwardscompatibility.htm
May 19, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
Brand new fable2 freezes on brand new xbox360 pro
Since your Xbox is brand new, you can just install Fable 2 to the hard disk of your xbox 360. I didn't have this problem with Fable 2 - but that's maybe because I installed it to the HD from the start. Fallout 3 did freeze on me, but installing it to the HD fixed the issue. Don't get any ideas though, you still need to insert the disk if you want to play ;-)
This is how you do it:
  1. Load the disk into your Xbox 360 console and go to your Xbox 360 console
  2. Scroll down to My Xbox
  3. Scroll across to Game Library and hit the A button
  4. This should put you on the Recent Games window and your game should be highlighted, so you should just need to hit the A button. Otherwise, scroll to the Recent Games window and choose the game.
  5. On the game screen, choose Install to Hard Drive. This process should take a few minutes, but once it is complete, you'll be able to enjoy improved performance.
You'll also note that the game screen contains all kinds of great information about the game such as the achievements unlocked and featured downloads available for the game.
Mar 08, 2009 | Microsoft Fable 2 for Xbox 360
New Xbox 360 Drive.. Need help flashing
You will need to backup the firmware from you original drive and flash it to your new drive as the old drive is tied to the motherboard with a 16 byte key
Sep 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20,228 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
