Question about Pioneer DEH-1600 CD Player
Pioneer car stereo display good but no sound
I have a Pioneer cd player head unit (can get model later if needed) in my boat. Has always worked fine but mice recently chewed the speaker wires. Upon replacing them I have display that shows normal operation but have no sound.
zeusfaber
  • 247 Answers
SOURCE: Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Posted on Mar 30, 2007
  • 55 Answers
SOURCE: Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Posted on Aug 30, 2008
SOURCE: Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
Posted on May 15, 2009
  • 773 Answers
SOURCE: PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Posted on Dec 15, 2009
  • 26 Answers
SOURCE: i bought a deh6 pioneer stereo to install in a
blk-ground
yel-constant 12v
red-switched 12v
blu-power antenna
blu/wht-amp turn on
orn-illumination
Speakers- black stripes are negative.
whites-front left
greys-front rights
greens-rear left
violets-rear rights
tape off any unused wires, do not let them touch ground or any other wire.
Posted on Mar 14, 2010
Testimonial: "thank alot, this was very helpful. "
CDs sound distorted
If you search on most good car stereo web sites, they will ask for your vehicle information, and will only show you head units that will fit your dash. You can also buy custom dash plates to fit non-OEM shaped units.
Apr 23, 2014 | Pioneer Lexus Gx470 Cd Changer 8627060070
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Need wiring diagram for pioneer cd player deh-p4300
that model is for an automobile, if you go to the website link I am posting look for your model of unit as you used to be able to download owners manuals as well as wiring directions for free but in the past you had to join the pioneers web site
athttp://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/ good LUCK!!!!
Larry Dillon
Aug 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Don't know how to set the clock on the Pioneer AVIC-D2 head unit
drop by your local car stereo dealer and ask them NICELY to reprogram the time for you...then, a NICE person would but the guy lunch, what $10?
Good Luck
Jun 15, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
DEH-960MP CAR CD PLAYER STEREO RECEIVER DISPLAY PROBLEM
its the ribbon wire inside i have the same deck with the same problem and it cost me 100$ to have it fixed since the warranty was no longer valid any pioneer repair place can do this for you. All you need to do is take them the head unit not the wiring harness so at least you dont have to unhook it all
Mar 14, 2009 | Audio Players & Recorders
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Help
do u like ur head unit (Pioneer DEH3700MP) , cuz i bought mine @ a car show for $40.00
Sep 17, 2006 | Pioneer DEH-P3700MP CD Player
Pioneer DEH-1600 CD Player Logo
380 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
