Samsung DVD-1080P8/XEU DVD Player Logo
Posted on Apr 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change region codes from only 4 to 2 & 4
It's a Samsung DVD-1080P8 dvd player. How can i change it from only playing region 4 dvd's to play region 2 & 4? Thanks
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Jul 29, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
34583
Points
156
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
Enjoy
Need a dvd decoder for samsung n102 sp
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
1helpful
3answers
Can't play uk DVD in Australia
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change. Region 4 = Australia
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
2answers
A DVD bought in Australia cannot be played in a samsung htz310i dvd player in the UK
Brigid,
The world has been fenced off into areas by these manufacturers, and you Aus DVD is security locked to Code 4.
The UK has a different Area code, and your Samsung was setup to play only DVD,s sold in Europe.
However a knowledgeable friend with a computer can play another areas disk by changing the area code in the computer.
Cheers
DeJudge
2answers
Unlocking region code on DVD Samsung VR 375 player
Though can try this:
1. Power ON
2. Press MENU
3. Enter code 57538
4. The current region code
5. For codefree press 9
6. Click on the Open DVD door button
7. Power OFF and power ON
8. Enjoy!
3answers
I have a samsung dvd r 120, two dvd's i rented
Is it possible that the region codes of the DVD player and the DVD's are different?
I want to play region 2 dvds on a region 1 player.
HELLO!
Try this website - www.videohelp.com and look in the DVD hacks section - I'm sure you may find what you are looking for!
ALL THE BEST (:-)
9helpful
Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
3answers
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
2helpful
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
28helpful
8answers
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
