Question about Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo
Audio I bought the Polaroid TV/VCR/DVD from Target in March. It was a floor model, so there's no warranty. Recently the audio has been flickering off and on -- usually turning it off for a bit helps, but it is finally totally gone. The TV was generally on mute during its use as the floor model, so the only problems I should have would be with the screen. Any suggestions as to simple ways to fix it? I'm hesitant to open it up myself but would rather not have to pay to have it transported and repaired at a shop.
  • 1,139 Answers
I would first see if the audio output stage is functioning properly. I would do this by plugging into the audio output RCA jacks with an audio amplifier and seeing if the audio is breaking up there if not the problem is in the stages after the jack tap off point if the problem is still present in the RCA jacks then the problem is before the RCA jacks. Now I would also take voltage readings of the audio output IC chips this includes bias voltages and the output signal voltages. of the input and the output of the chips (in case of stereo). This will tell you if you need to replace the audio ICs or not. Now what could be happening is that the audio control circuit could be at fault for this you will have to check the voltages on the command processor. There is no simple way to repair this problem, which does not involve opening it up. However there is a way to bypas, and I mean bypass the problem "THIS IS NOT A FIX" If the audio out of the RCA jacks is not effected you could plug an audio amplifier into them (Left and Right Stereo) and use the amplifier as your audio output. This is not a good practice, but it will get you by. I would suggest getting the set fixed though.
Posted on Sep 18, 2007
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
Hello. I recently bought a magnavox dvd/ vcr and attempting to connect it to my Sanyo DP32649-06 TV. The magnavox does not have the ant in or ant out plugs needed for my cable to appear on the...
Can you tell me the model # of the Magnavox?
What type of "out" connections does your Magnavox DVD have?
Old style Coaxial RG6?
Composite (Red and White for audio \ Yellow for Video)
Component (Red and White for audio \ Blue, Red, Green For video)
Jun 11, 2011 | Sanyo Televison & Video
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
No color and no audio
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
Jan 08, 2009 | GoVideo Go Video DVD/VCR Combo
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
No audio when using VCR/DVD player
the first thing that you need to do is use the video cables and audio cables that are on the back of the unit. This makes sure that you have sound and video.
Dec 22, 2008 | Sanyo DS27510 27" TV
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
No signal
Try connecting a DVD or VCR and use the video and audio from there to connect it to the audio and video input on your TV.
Hope this helps.
Feb 20, 2008 | Polaroid FLM-323B Television
Volume problem
audio output amplifier (transistor or IC) is bad
Dec 25, 2007 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Remote control problem
Have you tried "One for All" universal remotes?
Jun 10, 2007 | Polaroid 1720-7 Remote Control
Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo Logo
75 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
