Question about Canon MV850i Mini DV Digital Camcorder
How to download from video tape to computer
I have taken video from London in tape mode for 60 mts. Now I want to take it in computer and make a CD. Please tell me how to do that. what all required for that.
What is code 28
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } I bet people who use Sony and Cannon camcorders may feel frustrated trying to enjoy their videos on iPod, iPhone or iPad, as these videos are taken and saved in the form of mts/m2ts and they cannot play on these players. It used to be my trouble, too, but then I found I needed to convert mts to mp4. I found some powerful mts to mp4 converter so I'd love to share it with all you guys.How to convert mts to mp4?
Download and install mts to mp4 converter on your PC. It takes only a few steps to convert m2ts to mp4 on Windows.
Step 1: Connect your HD video camera/camcorders to your PC. Copy the source videos to your PC's hard-drive before converting or editing them.
Step 2: Launch the m2ts/mts to mp4 converter. Click "Add files" to browse your computer hard disc and add the .mts or .m2ts files you want to convert. You can load all the source files before the mts to mp4 conversion as batch converting is supported by this m2ts mp4 converter.
Step 3: Now you select mp4 as the output format and specify a directory for the output files. This mts/m2ts to mp4 converter supports comprehensive video formats including avi, mpeg, wmv, mp4, mov, xvid, 3gp, flv and more.
Step 4 (optional): The mts to mp4 converter can set the brightness, the contrast and the saturation of your videos, crop, trim videos and even merge multiple files into one single file before the conversion.
Step 5: Click the "Start "button to start the mts to mp4 conversion and all you have to do is to wait until the m2ts mp4 conversion is done.
Related article: How to convert m2ts to mp4 and How to m2ts/mts to mp4
Oct 04, 2010 | Microsoft Windows XP Professional
Tip
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality <br /><br />I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS in 50/60 progressive mode to ProRes</a></b> is necessary. <br /><br />I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected. <br /><br />Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to <b>Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X</b> that I've ever used. <br /><br />Here is the step-by-step guide to quickly <b><a href="http://canon-videoconverter.com/2011/07/transcode-sony-cx360-50p60p-avchd-mts-footage-to-prores-422-hq-for-fcp-x-editing/">Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X</a></b>. <br /><br />1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac <br />Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import. <br /><br />2. <b>Merging and converting 50p/60p AVCHD MTS files</b> to what you want. <br />After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate. <br /><br />3. Export Apple ProRes 422(HQ) for editing on FCP X <br />After setting the output format and frame rate, click the "Export" button and conversion from <b>1920x1080</b> 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts. <br /><br />After the conversion is completed, <b><a href="http://www.aunsoft.com/final-mate-mac/">Import and Edit ProRes 422 (HQ) on FCP X</a></b>. <br /><br /><b>Tips:</b> <br />If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and <b>play on WDTV Live with original quality</b>, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
on Jul 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing <br />Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion <br /><br />The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though <b>Final Cut Pro X</b> with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X. <br /><br />To edit the 1080/60p or 1080/50p <b>Camcorder AVCHD Videos to Final Cut Pro X</b>, the conversion from MTS/M2TS in 50/60 <b><a href="http://www.aunsoft.com/final-mate-mac/">Progressive mode to FCP X ProRes 422 (HQ)</a></b> or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes. <br /><br />The guide below shows you how to <b><a href="http://1080p-converter.com/2011/07/avchd-to-fcp-x-mtsm2ts-in-5060-progressive-mode-to-fcp-x-for-prores-422-hq/">Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X</a></b>. <br /><br />Step 1. <b>Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Run Final Mate for Mac as the best <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Cut Pro X and AVCHD</a></b>, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Choose <b>AVCHD files to FCP X ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly. <br /> <br /><b>Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.</b> <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode. <br /> <br />Wait for the conversion, and you can then import 1080 60p <b><a href="http://www.aunsoft.com/final-mate-mac/">HD videos to Final Cut Pro X</a></b> through the direct import and enjoy editing in FCP X. <br /><br /><b>Tips:</b> <br />If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: <b><a href="http://www.aunsoft.com/solve_no_video_problem_after_converting_avchd_to_apple_prores_for_fcp_x/">Solution to ProRes Video Issue in FCP X</a></b> on aunsoft.com.
on Jul 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
I have g4 mac 9.2. i need saported softwer for braus & plye vediyu
Leawo Video Converter is an all-in-one best video converter for downloading to convert videos among popular formats like AVI, MPEG, WMV, MP4, FLV, RM, MOV, Xvid, 3GP, etc., transform audios between MP3, WMA, WAV, M4A, AAC and AC3 audios, and create fascinating photos from video files.
Oct 04, 2010 | FLVPlayer4Free
Tip
Convert Sony TX100V 1080/60p MTS to AIC MOV for iMovie 11 and keep the raw...
Convert Sony TX100V 1080/60p MTS to AIC MOV for iMovie 11 and keep the raw quailty
The Sony DSC-TX100V is on the iMovie '11 compatibility list, But it's a AVCHD 1080/60p camera -- iMovie '11 supports only 30fps! The Sony DSC-TX100V another option for 1920 x 1080/60i which equates to 60 interlaced fields per second, but the video quality of 60i recording mode is not better than 60p mode, so personally i prefer to choose 1080/60p for recording mts footage.So if I want to edit Sony DSC-TX100V 1080/60p .mts video with 60fps high quality for iMovie 11 on Mac, must to convert Sony DSC-TX100V 1080/60p .mts files to iMovie 11 before editing.
After google search , I need convert my Sony DSC-TX100V 1080/60p .mts to Apple Intermediate Codec MOV for iMovie 11 with keep the raw quailty, I found Final Mate for Mac is the recommended can convert Sony DSC-TX100V 1080/60p MTS to 1080/60p AIC MOV for editing on Mac. Then I download and try it. And I had succeed with the Apple Intermediate Codec at 1920x1080 60fps editing for iMovie 11 and i'm very satisfactied with the output quality after uploading the videos on Youtube.
Here is the step-by-step guide to quickly convert Sony DSC-TX100V 1080/60p MTS to AIC 1080/60p (*.mov) for editing in iMovie 11 on Mac.
Step 1. Directly download 60fps .mts files from Sony DSC-TX100V to Aunsoft Final Mate for Mac.
Connect Sony DSC-TX100V to PC via USB cable. You will face the pop-up message asking you to use camcorder wizard or not. If you do not get the message, just click the Wizard button. Click Yes and follow the wizard to download/import 1080p files to the program.
Step 2. Create a Movie for Converting Sony DSC-TX100V 1080/60p MTS files to AIC 1080/60p MOV.
Method 1): Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created.
Method 2): Click downlist of Add button and select for conversion. A blank movie is created. Then drag and drop your Sony DSC-TX100V 60fps .mts files to such a movie for merging together and making a conversion.
Step 3. Export AIC MOV video file.
Click the Export button and choose "Export into Editor". Follow iMovie and Final Cut Express > Apple Intermediate Codec (AIC) (*.mov) to choose export format for further editing in iMovie. In this way, all video clips will be merged as one single movie for convert to iMovie.
Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 60, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality.
After the conversion, the AVCHD videos could be imported and recognized by Mac iMovie 11 with 60fps highest quailty. And after editing you can upload the best quailty .mts files to Youtube for share.
Tips: The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V,; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camocorder , plaease visit the Camcorder column for more information.
on Jun 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to Play AVCHD with Sony DSC-HX5V on VLC Media Player? After recording some...
After recording some HD videos with the new Sony Cyber-shot DSC-HX5V, do you want to play the videos on computer? You may face the problem that the full HD videos at 60 fps in .mts file format do not play properly, and the playback on VLC is choppy.
If the VLC media play shows the HX5V .mts video, but with pixelation or interlaces, you can adjust VLC to see if the video playback on VLC is perfect without interlacing artifacts. Just play the video as normal videos on Mac, and right click on the player to choose Video > Deinterlace and choose the options like Discard, Blen, Mean, Bob, Linear, X, Yadif, Yadif (2x).
If the above solution does not work for you, you may try Mac Sony DSC-HX5V MTS converter to deinterlace AVCHD, convert HD .mts to HD .mov, HD .mpg for VLC media player. The output HD MOV is compatible to QuickTime too. Here are the simple steps to convert Sony Cybershot DSC-HX5 .mts to HD .mov with Aunsoft MTS/M2TS Converter for Mac.
Step 1. Load Sony DSC-HX5V videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony DSC-HX5V MTS converter, and click the Add button to load .mts videos.
Step 2. Choose HD .mov output.
Click the Format option and choose HD Video > H.264 AC3 HD Video(*.mov) for converting .mts to .mov.
Tips: The Mac Sony DSC-HX5V MTS converter will convert 1080i AVCHD to 1920x1080 by default. If you records videos at 1440x1080, you can click the Settings button and change video resolution by choosing 1440x1080 from the drop down menu.
Step 3. Convert Sony DSC-HX5V .mts to HD .mov.
Click the convert button under the preview window, and the conversion from Sony DSC-HX5V .mts to QuickTime HD .mov starts immediately.
When the conversion is finished, you can play 1080p videos on VLC without interlaces or choppy problem on Mac. Your QuickTime will play the HD .mov videos seamlessly too. The Mac Sony DSC-HX5V MTS converter would work perfectly on Mac Leopard, Snow Leopard for your iMac, MacBook Pro.
on Jul 15, 2010 | Computers & Internet
HF10 camcorder cannot read some .mts files
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Remember M2ts files need to be converted to Progressive non HD files so your computer can read them. That will stop the choppy skips.
Hope this helps.
Jun 04, 2009 | Canon VIXIA HF10 HDV Camcorder
Tip
Transfer/Edit Sony HDR-TG3 1080i AVCHD Videos on Windows/Mac Sony Handycam...
Sony Handycam HDR-TG3E is a super small camera with full HD recording on Memory Stick in 2008. It includes 4GB and 10x optical zoom for capturing 1920x1080 and 1440x1080 videos. However, this camera does not include progressive recording mode, which indicates that the HD videos are 1080i. Even though it is compact camera, the audio is recorded in Dolby Digital 5.1ch. You can also take 2.3Mp stills while you are recording video footage.
Sony HDR-TG3E features:
- 1920x1080i HD video recording
- 4 megapixel still photo recording
- Dual Rec simultaneous 2.3 megapixel still photo during video recording
- Handy face detection
- Carl Zeiss Vario-Tessar lens
- ClearVid CMOS Sensor and Exmor derived technology
Videos from Sony HDR-TG3E:
Movie Format:
- High Definition: AVCHD (1920 x 1080, 1440 x 1080) in .mts filename extension
- Standard Definition: MPEG2 in .mpg filename extension
Movie Quality:
- HD: FH (1920x1080i, 16Mbps) / HQ (9Mbps) / SP (7Mbps) / LP (5Mbps)
- SD: HQ (9Mbps) / SP (6Mbps) / LP (3Mbps)
Transfer & Edit Sony HDR-TG3 AVCHD videos:
For Windows users:
Install the Picture Motion Browser (PMB) from the bundled CD in box, and connect Sony HDR TG3 to PC via USB cable. Use Sony PMB to download HD .mts videos from camcorder to PC.
For Mac users:
You can capture and transfer Sony HDR-TG3 1080i videos to iMac/MacBook Pro via iMovie after connecting camera to computer with USB cable. However, you may face problem when trying to log and transfer AVCHD videos from Sony Handycam HDR-TG3E to Final Cut Express (FCE) 4 or Final Cut Pro (FCP) 5. After transferring HD .mts videos from camera to computer hard drive, just run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-TG3 MTS converter to deinterlace .mts videos and convert .mts to .mov for FCE and FCP, if you want to edit HD videos.
Alternative way to transfer HDR TG3 videos for Mac and PC:
Just connect HDR TG3 pocket camera to computer via the USB cable, and the HDR TG3 will display as a hard drive on computer. Navigate to the HDR TG3 hard drive to access the memory stick.
Tips: Sony Handycam HDR-TG3E is the model for Europe, and Sony Handycam HDR-TG1 is the model for US.
on Jul 14, 2010 | Cell Phones
Canon MV850i Mini DV Digital Camcorder Logo
146 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
