Question about Nintendo GameCube Console
Getting 'Disc could not be read' after few seconds
After connecting GameCube and I have inserted the disc and started playing game. After few seconds, the screen is Displaying as 'Disc could not be read.Please read the GameCube instructions'.
  • 36 Answers
Try spinning the kisk with your hands
Posted on Jan 09, 2010
  • francisc gonzalez Jan 09, 2010
    try spinning the kisk with your hands
SO i went to play sonic hereos last evening and the disc has no scratches or finger prints on it and the disc is fine so I put it in my gamecube and turn it on and then it says the disc cannot be read so I...
Same thing with my gamecube console so I was getting ready to play my gamecube games and it said the disc cannot be read so I decided to check my disc;s and they look fine no scratches or dirt on them. So I tried it on a wii instead and that message didnt occur so the laser inside of the gamecube console leaser
is weak or it needs to be adjusted.
10 Stars if this solution is helping you out.
Mar 16, 2012 | Nintendo GameCube Console
It dont wont to read the disc
Well i just went to put in Sonic hereos and tried my other gamecube games and no scratched discs and the discs look to be fine so the laser needs to be replaced or is a weak laser then. But the wii is fine so my gamecube might have internal problems then.
Dec 22, 2011 | Nintendo GameCube Console
I inserted my game and it said "the game disc
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance
Feb 20, 2011 | Nintendo GameCube Console
I have a gamecube.on the game smashbrothers,it will play for a few moments and then it says:can't read disc,refer to gamecube manual but i don't have one.please tell me what to do.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 begin_of_the_skype_highlighting 1-800-255-3700 end_of_the_skype_highlighting for assistance.
Jan 19, 2011 | Nintendo GameCube Console
Sonic heroes (gamecube) can't be read
it might not be that its too dirty to play, but that its to scratched for the disc to be read. I suppose there are a bunch of home remedies you could look up, or you could by some sort of scratch repair tool for your game
Jul 07, 2009 | Sega Sonic Heroes for GameCube
Gamecube Recognizes what game the disc is, but cannot read it
Make sure its in the right way (image facing up) then close the lid and press power button it should load the game up automatically (dont hold a after switching on the gamecube. if it persists take out the disc wipe it again blow on the gamecube to remove and dust then try switching on the gamecube without the disc it should show the menu, press up and there should be a question mark, insert disc, there it should show the game, press 'A' to confirm, then press start if it persists it is recommended you get it checked out because it could be the case that the disc is badly written like my lego starwars 3 on one of the levels it goes wierd and it spoils it really (i think there is a problem with all starwars games personally). Anyway Hope i helped as much as i could.
Apr 30, 2009 | Sega Phantasy Star Online: Episode I and...
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
Wii/Gamecube game
Yes you can play gamecube games with no emulators. The memory card slots and controller ports are located on top.
Dec 06, 2007 | Nintendo Wii Console
Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
Oct 13, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
601 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
