Question about Motorola Mobility RAZR V3
DISPLAY LIGHT PHONE WORKS, DISPLAY LIGHT DOESN'T
  • COOKIEMOBILE Sep 20, 2007
    NO, IT LOOKS LIKE I HAVE TO SEND IT INTO MOTOROLA TO BE REPAIRED. I WAS TOLD THEY HAVE QUITE A BIT OF PROBLEMS WITH THE RAZOR PHONES/
    Brigadier General:
  • 7,752 Answers
Take the phone and have them replaced the flexcable, this will correct the phone issues that you are having.
Posted on Feb 17, 2008
SOURCE:
How can i format if my display doesn't work
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Format it
Jan 16, 2013 | Nokia Classic 2330 Cell Phone
My nokia 6300 is all the lights i.e. display and keypads lights the are working the display has become black and white can u give me some instructions
Hello your problem is not relating to Lights,but possible problem comes from the failure of LCD/LCD socket/ Display IC (filter).So, to solve this you can at least open the case and clean the components/board near the display socket Or Re-insert the LCD.If this trick doesn't helps contact nearest mobile repairing shop.Good luck
Jul 22, 2012 | Nokia 6300 Cellular Phone
Why is it the lights are not on my keypad
GO TO DISPLAY SETTINGS THEN CHECK FOR KEYPAD LIGHTS AND ACTIVATE IT......
Oct 20, 2011 | Cell Phones
I have a nokia 7610.when i turn it on, i can only see the white display.i even changed the display.
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 08, 2011 | Computers & Internet
Had a power outage during a lighting storm and now the GE spacemaker phone/unit does not work; it's showing in the display screen "Initializing". The phone works, but when you press any of...
Does it have a battery backup? If so, after disconnecting the AC power adapter, remove the battery for 15 minutes, then re-insert it (make sure it is a good battery), plug the AC adapter back in, and try again. Hopefully, this will re-set it. If not, it probably isn't worth tryiing to repair. May have to buy a new phone.
May 06, 2017 | GE Spacemaker 26976 Cordless Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Display not lighting up
i think whoever squeezed ur phone,squeezed WAY to hard and took the color cartirge out.try gettinbg a new 1.i have NO idea about the volume...
Jul 18, 2008 | Motorola Mobility V31 RAZR GSM Cell Phone,...
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
