There is no toggle/powerbutton on the face of the tower
I have a emachine tower it seems to have everything ecepted the power button to turn it on with,so i wanted to see or understand were to plug one in on the motherboard thanks
  • 700 Answers
If this is atx power it should be just push to on button look for something that can be depress. On motherboard connection follow motherboard manual. It should be on a header. Together with the reset, power led light, hd LED and the power itself.
Posted on Apr 18, 2009
Emachine E109t6w flashing power button
means it has no signal and/or it is asleep. make sure all your connections are connected properly. if you have unplugged or plugged in the monitor lately make sure you don't have any bent pins on the vga cable.
Apr 12, 2012 | E-Machines eMachines Desktop PC
On off button not working
We need to follow some Troubleshooting steps
power off the tower
disconnect the power cable
1.open the side panal of the tower
2.then open the front panal of the tower
3.the please toggle the power button from inside the tower
4.then put back the front and the side panal
connect back the power cable
restart the pc using the power button
it will start working
Jan 13, 2011 | HP Compaq Presario SR1830NX PC Desktop
I have an emachines T1440 desktop. the front face of the machine is broken, the power cord, and the wires from the power cord to the power supply box. What type of case or tower can i use the remaining...
Luckily, eMachine uses a generic system board. You can purchase a case from any computer store. The only thing to watch for is the plate in the rear of the motherboard, make sure it matches your ports. Again I believe you can use the one from your eMachine.
Nov 12, 2010 | eMachines T1440 PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Feb 06, 2009 | E-Machines D2046 PC Desktop
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
Detecting array...
does any other monitor work? if not than the video card may be bad. or the settings in the bios may be altered. first try this...unplug the tower, open the case and remove the bios/real time clock (RTC) button cell battery, press the power button to dissipate any voltage that is stored. Re-install the battery, plug tower in and power up. If anything was changed in bios everything would go back to default settings and you would have to enter set up to update date/time etc.
Sep 10, 2008 | E-Machines eMachines Desktop PC
My emachine desktop is not not coming on
I've owned nothing but e-machines towers for probably 9yrs. I've had this exact problem with two of them already. E-machines are notoriously known for power supply problems (which is usually about a $50 fix), but oddly enough the two problems I've ever had with the tower not powering up, resulted in being a problem with the motherboard. You can order another one, but it's VERY costly. Odds are that your info is still perfectly intact on your harddrive. When I experienced this problem, I removed the harddrive and installed it as a backup drive within a new tower. (I know you probably ask 'why keep buying them', but in my opinion, Gateway does a REALLY good job of keeping their "e-machines line" with up-to-date features and it's definitely hard to beat the low price!)
If you still have a perfectly functioning monitor, keyboard, mouse, printer, etc, you may want to consider buying just a new tower (approx $250-$400 depending on brands)
Oct 22, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
