Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana ABB1927DE lower drawers freeze and lock potential
My lower storage drawers often freeze my carrots, celery etc. Also, I was wondering if there is a way to lock the refridgerator for curious culinary toddler raids.
  • 2 more comments
  • valmom Oct 08, 2007
    Thanks very mcuh. I'm sure this will help! I'll give it a try!
  • greggfabro Sep 15, 2008
    my lower storage crispers often/always freeze my lettuce etc
    I have a kenmore/amana bottom mount refrigerator model 59669872990 serial number 0004141682 bought june 2000......and otherwise has always run fine.........except just recently it has started to freeze my lettuce etc
  • cjm1959 Dec 29, 2008
    This is crazy! I have the same fridge and problem. I have had my fridge for about 7 years and it has always been great. Now my vegetables are freezing in the drawers.
    I will take the advise of making sure the drawers are closed tight. Any other thoughts would be greatly appreciated.
I had the same problem: I would put the refrigerator control all the way down to 1 and the items on the lower shelves were still freezing. I also had ice building up in the freezer. An immediate solution is to DEFROST the refrigerator. Ice can accumulate in the vents and obstruct the air flow. If that works but the refrigerator fails again after a short time, then the problem is likely to be in the defrost circuit. It is possible to engage defrost by rapidly switching the freezer light switch 5 times (usually activated by the door, but do this by hand). Doing it again will put it back into cooling mode. You may not be able to tell if it is working unless you remove the back freezer panel and see ice melting or determine that the heater element gets hot. If defrost doesn't work, then you've got your problem. If you want to fix it yourself and can handle electrical circuits, the circuit diagram is usually tucked in under the kick panel.
Posted on Sep 25, 2008
  • 473 Answers
Cold air settles to the bottom of the fridge. Things that can freeze easy may if the door is closed for long periods of time. This is a normal condition for any refrigerator. Look to see if there is a vent that goes to that drawer and close it all the way. That may make a difference.
Posted on Oct 07, 2007
Can I oven bake oxtail from frozen
issue i see is will take longer to cook
ox tail normally thawed before cooking
oven baking dish or pot or slow cooker is another option with lots of water and vegies etc
into a frying pan browned all over to seal in flavor and juices
Use tongs to remove oxtails to a plate, setting aside.
2 Saut? onions, carrots, celery: Add the chopped onion, carrot, and celery to the pan.
Cook for a few minutes until onions are translucent. 3 Add oxtails, garlic, bay leaf, thyme, salt, stock, wine, then simmer: Add the oxtails back to the pan.
let me know when dinner is ready
Jan 14, 2017 | Ovens
My refrigerator section freezes up, carrots, celery, etc.,
turn the temp dial down then to a less cold setting
Mar 29, 2015 | Refrigerators
What kind of foods can i cut with a kitchen slicer?
Kitchen slicers usually cut, slice and shred all kinds of food. You can use them for fruits like apples, bananas, pineapple, lemons, strawberries and tomatoes, or for veggies like cucombers, peppers, onions, carrots, celery, and for other foods, like eggs, deli meat, potatoes etc.
Oct 24, 2013 | Home
Upper unit freezes up even tho both top and bottom are turned down. only does it occasionally
Its the defrost problem. The drain hole is clogged and water freezes in the unit instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/amana-abb1927de-bottom-freezer-upper.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Amana ABB1927DE Bottom Freezer...
I juice mainly green vegetables: kale, spinach, etc, then carrots -and it doesn't have enough power, slows down and then stops - any idea why?
Sorry, but it's not designed for leafy vegetables.
Carrots, apples, celery-yes. For kale, spinach
try a inexpensive, hand powered, wheat grass
juicer. About $50.
Jul 28, 2010 | Acme 5001 Supreme Juicerator Juice...
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
Oct 02, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Carrots and celery get soggy and limp in fridge
try turning ur fridge down to about 4 and a 1/2 maybe 3
Sep 01, 2009 | Refrigerators
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
210 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
