Question about Transcend T.sonic 612 MP3 Player
Error formatting pendrive
I have san disk 4 gb pendrive ..it shows me unknown file format and always shows the errr message"UNABLE TO FORMAT" in windows vista..i tried ms dos formatting...diskpart..mbrwiz..bt not workd...plz suggest me answer as soon as possible...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes and scan your whole system as well as your pendrive
I
Posted on Jan 03, 2010
  • prashant aggarwal
    prashant aggarwal Jan 03, 2010
    your pendrive is infected with Autorun.inf virus
    I
  • prashant aggarwal
    I
I cant access and format my pendrive even though nothing show in pendrive but when i go in properties option then pendrive memory show full please give me solution of this problem
Go to your Desktop. Right-click on My Computer and select Manage. On the left-hand pane there should be an option for Disk Management under "Storage". Click that. Look for your drive. You can usually recognize it by it's size.
There are several things you can do from there. You can reformat it, and assign it a drive letter. Or maybe it may need to just initialize. Usually you can play around in there and get it to work.
If it does not come up, chances are that either 1: Flash drive is bad or 2: USB port(s) is not working.
Apr 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I am having transcend pendrive jfv30/8gb.when i format it unable to format and not showing memory thanks.
Hello welcome, this is 1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME.what you need to do.
Jan 20, 2011 | Computers & Internet
2 GB PENDRIVE SHOWING UNABLE TO FORMAT. AND ASLO
You can try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 07, 2010 | Transcend (589307) Media
40 GB Kingston Pendrive Showing 8 MB & unable to format it.
Format it using a format utility which you can download it from any free software sites, type in format utility.
May 04, 2009 | Pen Drive IVO MP3 Player
I have 8GB pendrive of transcend. when ever i want to format it, screen shows that window is unable to format it. i have window XP SP2
format it by dos
start>
all programs>
run>
type cmd
format it by
format g:(you type in ms -dos)
if you drive is f then
type
format f:
Mar 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive not work
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jan 30, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Displaying write protected while loading and deleting files
Dec 11, 2008 | Transcend (589307) Media
I am unable to format my Maxtor One Touch III 500gig External Hard Drive. Once i get to 100% using ms disk manager, a message box pops up saying that it was unable to format the hard drive. In linux when i...
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Mar 22, 2008 | Computers & Internet
Formattin of pendrive
Your pen drive probably lost or never had a partition table. Unallocated space means the space isn't allocated to either a partition or logical drive.
Rightclick the drive in Disk Management, there should be an option to create a partition. Right after you create it. It wil ask you to format it.
Let me know whether it helped.
Please rate my solution when this was the answer to your solution.
Greetings,
DarkNeogen.
Jan 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Transcend T.sonic 612 MP3 Player Logo
122 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
