Question about Cuisinart DCC-1200 Coffee Maker
We have a cuisinart coffee pot DGB500R that no longer works
Our coffee pot will work at times but only 4 cups and no more..can you tell me what may be wrong with it...thanks so much
  • 85 Answers
Hello bubsie53,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 06, 2009
Replacement 10 cup glass coffee pot
  • Items found similar to "GEMCO 10 Cup Glass Replacement ... www.ebay.ca/sch/sis.html?_nkw=GEMCO 10 Cup Glass Replacement Coffee... Items found similar to "GEMCO 10 Cup Glass Replacement Coffee Maker Carafe Decanter"
  • Items found similar to "BUNN Black Coffee Pot Carafe 10 ... www.ebay.ca/sch/sis.html?_nkw=BUNN Black Coffee Pot Carafe 10 Cup... Please enter a minimum and/or maximum price before continuing. C $ Enter minimum price to C $ Enter maximum price ...
  • One All 10 Cup Glass Eurostyle Universal Replacement ... www.amazon.ca/Glass-Eurostyle-Universal-Replacement-Carafe/dp/...
    • 4.7/5
    • 7 REVIEWS
    • ONE-ALL
    One All 10 Cup Glass Eurostyle Universal Replacement Carafe, Black: Amazon.ca: Home & Kitchen ... This replacement pot fits perfectly with my Braun coffee maker, ...
  • Bunn 10 Cup Replacement Glass Coffee Maker ... - ebay.com www.ebay.com > ... > Coffee & Tea Makers > Replacement Parts & Accs
    • SELLER 100.0% POSITIVE
    • KNIGHTDALE, NORTH CAROLINA
    BUNN 10 Cup REPLACEMENT GLASS COFFEE MAKER CARAFE DECANTER POT Black in Home & Garden, Kitchen, Dining & Bar, Small Kitchen Appliances ' eBay
  • images of Replacement 10 cup glass coffee pot bing.com/images 7f4o0&w=143&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">c03o0&w=148&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">0e6o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">3c4o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of Replacement 10 cup glass coffee pot
  • MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP ... www.ebay.com/sch/sis.html?_nkw=MELITTA+REPLACEMENT+GLASS+COFFEE... Find best value and selection for your MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP MINT search on eBay. World's leading marketplace.
  • Replacement 10 cup glass coffee pot - Fixya www.fixya.com > Forum > Coffee Makers & Espresso... Replacement 10 cup glass coffee pot - Coffee Makers & Espresso question
  • REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup ... www.ebay.com/sch/sis.html?_nkw=REPLACEMENT-Coffee-Maker-GLASS-POT... Items found similar to "REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup-"
  • Amazon.com: Medelco 10 Cup Glass Eurostyle Universal ... www.amazon.com > ... > Coffee Machine Accessories > Coffeemaker Pots > Fits my Braun 10-cup coffee maker perfectly. ... Medelco Glass Eurostyle Universal Replacement Carafe - Black, 12 Cup 3.5 out of 5 stars 109. ...
  • Cuisinart® 12-Cup Replacement Carafe in Black ... www.bedbathandbeyond.ca/store/product/cuisinart-reg-12-cup...
    • $34.99
    ... > Cuisinart® 12-Cup Replacement Carafe in Black ... 12-Cup Programmable Coffee Maker in ... original glass coffee pot and the replacement pot fits ...
  • One All Universal 10-Cup Eurostyle Glass Replacement ... www.walmart.com > ... > Kitchen Appliances > Coffee & Espresso Makers
    • 4/5
    • 15 RATINGS
    • $7.84
    • IN STOCK
    Buy One All Universal 10-Cup Eurostyle Glass Replacement Carafe, Black at Walmart ... 10-Cup Eurostyle Glass Replacement Carafe, ... Cup Glass Coffee Replacement ...
  • Mar 10, 2016 | Coffee Makers & Espresso Machines
    I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
    Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
    Regards,
    Harry B.
    Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
    My 12 cup cuisinart coffee pot keeps shutting off
    I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
    Mar 20, 2010 | Cuisinart DCC-1200 Coffee Maker
    Coffee doesn't brew full pot
    Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
    -Tha Mp3 Doctor
    Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
    Question about cuisinart's DCC-1200 1-4 cup mode
    The 1-4 cup setting actually loops the water through the heating element twice. It's a good wrokaround for people who like extremely hot coffee, but not for iced coffee fans like me.
    -Tha Mp3 Doctor
    Dec 21, 2008 | Cuisinart DCC-1200 Coffee Maker
    Cuisinart DCC2000 quits brewing after 1or 2 cups
    Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
    Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
    Cuisinart Grind & Brew not using all the water in the reservoir
    I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
    Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
    It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
    Dec 10, 2007 | Cuisinart DCC-1200 Coffee Maker
    Buy new coffee jug?
    Replacemet pots for the DCC-KE12 coffee makers is Cuisinart DCC-1200PRC 12 cup replacement pot.
    May 03, 2007 | Kenmore DCC-KE12 Coffee Maker
    Cuisinart DCC-1200 Coffee Maker Logo
    113 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
