Question about GE (PSS26MSRSS) Side by Side Refrigerator
Bottom of frig freezes, top is 60 degrees
I have a GE side by side. The freezer just had a fan replaced because it wasn't freezing. Now the lower part of the frig side freezes and the upper part of the frig side is warm
  • 2 more comments
  • rjnbiker Apr 20, 2009
    top ias warm frost on back not cold enough
  • itsmejujufay Apr 26, 2009
    get cold but not cold enough to freez ice
    and also gets frost on the back wall of the freezer
  • bishopstudio Apr 29, 2009
    Thank you for the suggestion. The gaskets are fine and the door shuts nicely. The repair guy also felt that the "door" as he called it that is between the freezer and frig seemed to be working.
  • kulig44 May 01, 2009
    top of the freezer is warm and bottom is very cold.Today I replace the evaporator and the freezer motor is not warking,fan is not moving cold air up.
    Genius:
  • 1,198 Answers
Check your door fit. The gasket should be tight all the way around, you can push the door back into shape.
Posted on Apr 27, 2009
Hot on top, cold on the bottom on both sides
Mine did the same thing and the circuit board that controls the fans had gone bad . It could be that or the fan itself.
Jun 06, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side GE frig's freezer is not freezing solid
This repair was done for the same complain. I replaced evaporator fan motor and main relay board. Hope this helps.
Nov 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LSMFBS IS FINE IN THE FREEZER SIDE BUT FREEZES IN THE REFRIGERATOR SIDE.
Sounds like you need to adjust your airflow into the frig compartment. There are two adjustments for air flow on a side/side one at top next to thermostat and one at bottom next to crisper. If your freezer is working properly like you say then you just simply need to balance the airflow to get the proper temp of just above freezing to 40 degrees
Jul 27, 2009 | GE Profile Arctica Stainless Steel Top...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
239 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
