Aspire one netbook seems to boot up but the LCD monitor does not display anything.
  • Travis Caverhill
    Travis Caverhill May 11, 2010
    Have you recently connected it to an external monitor/projector?
  • 30 Answers
If u do not want any backup then u can make recovery using vista or installXP after formatting.otherwise u have to check whether u pass to safe mode or not then after all are not working then u have to chekit out with ur vendors
Posted on Aug 04, 2009
How do i fix white screen on my kav60 acer aspire one
The KAV60 is also the AOD250.
Netbook OFF, monitor OFF, connect an external monitor to the netbook's VGA port.
[You can use a VGA monitor. Looks like a small TV.
This is an example of a VGA port,
VGA connector Wikipedia the free encyclopedia
Note* VGA port doesn't have to be blue in color ]
Turn the monitor on. Turn the netbook on.
If there is no image shown on the external VGA monitor, press and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(The F5 key is the Display Toggle-Over key)
No image on external VGA monitor?
Hold the Fn key down once more, and tap again on the F5 key.
Still no?
Problem is internal in netbook. Probably graphics chipset soldered to the motherboard.
Replace motherboard.
Image shows on external monitor?
Problem is with Video Cable or laptop LCD screen.
MOST of the time it's the Video Cable.
The Video Cable connects to the motherboard, in an area under the Keyboard. It then routes up under the left Hinge, and into the Display Panel.
Inside the Display Panel it then connects to the LCD screen.
With frequent opening and closing of the netbook, the Video Cable can be pulled on. This can cause damage to the Video Cable.
(Stretched/broken wires inside the sheath of the cable)
And/or it can cause the connection at the motherboard to be loose, and/or at the LCD screen.
Example of Acer Aspire One video cable,
For ACER Aspire One D250 LCD Screen Cable DC02000SB10 KAV60 New
You can remove the Video Cable, and check it's continuity with a multimeter, or if the cost is reasonable to you simply replace it.
8 to 10 dollar video cable is not the problem? Then problem is the LCD screen itself.
My money is on a loose video cable connection, or damaged video cable.
For additional questions or to have me clarify/simplify anything in my solution, please post in a Comment.
Regards,
joecoolvette
Jan 15, 2015 | Acer Computers & Internet
Acer aspire one 725; netbook is working, but i don't have any backlight..
Connect it to an external monitor. If there is a display there, your lcd needs replacement.
Oct 10, 2013 | Acer Aspire One Netbook
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Acer netbook will not boot up green power light on, but screen does not show
- try connecting an external monitor. if get a display on the external monitor then there is a problem with the LCD or the LCD cable on your laptop. if your still not getting video then try booting to BIOS (F2 or Del when you turn on the computer). if you are able to boot the BIOS troubleshoot the operating system. if not then you might need to get the video card or the motherboard replaced
Mar 27, 2011 | Acer Aspire One A150-1049 Notebook
2/3 of display is black
Strange could be video card issue or broken screen. try connecting it to TV or another monitor see if the picture is clear than video card is fine and display is damaged
Mar 02, 2011 | HP Mini 1000 Netbook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer netbook Aspire One doesnt support extarnal LG Monitor L192WS.How can I get the monitor to work properly?
First have you turned the port on for the monitor ? if not it usually is a function key like F2 ect. If this is done the right click on a free space on your desk top > then properties > settings tab ....and make sure you have two display checked in the drop box.
May 30, 2009 | LG Flatron L1750S 17" LCD Monitor
I'm trying to usse my acer aspire one with an Hp sb21 lcd projector and it won't work. Any ideas? As the computer boots the projector shows the windows screen, but when it goes to the desktop, the...
You might have not enabled your computers second display.
This is actually a very nice feature, because you could run your powerpoint slide on the monitor while still running your normal applications on the laptop screen.
Go into control panel, display properties and then click on the "second" monitor (you could click on "Identify" to see which is which) and then select the "expand my desktop onto this screen.
The LCD display will be just a normal background, but you can drag windows from your laptop screen onto the LCD and back.
Hope this helps
Apr 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
David Payne
David Payne
