Laptop will not boot
Hi, I have an HP omnibook 400, with what appears to be a smoked hard drive. When powered on, the drive will briefly start to spin up, then spin down and emit a "whoop whoop whoop" tone reminiscent of "red alert" on the old Star Trek series. The PC continues to try to boot, finally reporting "No OS found". When entering BIOS Setup, the hard drive is not detected. I don't mind buying a new HD for the PC, but was wondering if anyone else has experienced this rather odd failure before I buy an new drive and find the failure is more insidious.
  • vlstu Apr 18, 2009
    This was good diagnostic info. I was able to pull the hard drive, and re-seat. In doing so, I discovered the spinning noise created at power on was the system fan, not the hard drive. I also checked the BIOS, and it is maintaining the clock time -- so I am assuming the onboard battery is working.
    I am now down to the dilemma of determining if the drive is bad or the disk drive controller.
  • 326 Answers
You may be able to repair your hard drive, and continue using it.
Visit the link below and decide if this utility is worth it to you. It is a small but extremely powerful tool used to repair hard drives back to their original state. It also provides exceptional preventative maintenance. I am not selling you this product. I am simply letting you know what we use and of its existence. If the benefits are important and interesting to you, then this tool may help your problem, if not just your future investments.
http://www.grc.com/sr/spinrite.htm
Other options are to assure a positive connection between your drive and the computer. Examine the bottom and edges of your laptop for access panels held in place by screws.
There should be labels or symbols (a short cylinder, or stack of cylinders, the letter s, the letters HDD, HD, etc) Remove any screws found on the edges of this pannel and assure that your drive is infact making good connection with the laptop by applying light but steady presure.
You have another possible issue that may be caused by a backup battery dying, and your settings reverting to default. Address your boot settings in the BIOS if you have not already.
If this information was helpful please rate the solution. If you have any further questions, please do not hesitate to ask.
Posted on Apr 18, 2009
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
How do I upgrade the Intel Pentium 4 CPU in my omnibook xe4400s; thanks reastonmd@cox.net
No, this is a mobile processor, see spec here. HP Omnibook XE4000 and HP Pavilion ZE5000 Product Features and...
it integrates with the laptop for saving battery power and the chipset.
To speed it up, put in a much ram memory as allowed,.
Defrag the hard drive to speed it up.
Check your drivers are up to date, this may speed it up.
Feb 12, 2015 | HP OmniBook XE4400S PC Notebook
My HP DV7 laptop will no power on. The LED next
try pulling the hard drive loose and see if it tries to boot and comes up with no boot device found if it does the hard drive is bad if not the bios is corrupted and will need the bios reflashed.
May 08, 2010 | HP Pavilion dv7-1130us laptop
What type of hdd does a HP omnibook 6100 F3260KT support and can it hold more than 30 gig standard factory as current HDD heads are locking up
The type of hard drive you want is a 2.5 inch IDE (ATA) hard drive.
As for the HDD capacity I've worked on an Omnibook 6100 which had a 100GB hard drive so i expect it can possibly take up to 320GB but don't quote me on that.
Regards.
Nov 13, 2009 | HP OmniBook 6100 Notebook
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
My HP Pavilion laptop will not boot.
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Apr 12, 2009 | HP Pavilion dv8000z Notebook
WHEN I START MY HP LAPTOP AFTERTHE WINDOWS XP APPEAR IT JUST STOP
It's not booting to the OS I take it. THen you need to do a recovery it you have one. First try F8 key when you turn laptop on try safe mode see if that boots. If it does restart F8 again try last know see if that one work that would be your last start up backup if that works you should be ok. If not then go to setup do boot from CD install your Windows CD restart your laptop and try doing a windows repair if that does not work then you will have to do a complete reinstall.
Good luck
Mar 20, 2009 | HP OmniBook XE3 Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
OmniBook XE3 Boot Problems
did you replace the ram?
If so take it out and see if it starts up.
Nov 28, 2007 | HP OmniBook XE3 Notebook
Computers & Internet Logo
David Payne
David Payne
