When it works on hi cool after sometime the blower stop but compressor still working .my aircon is window type.
    President:
  • 1,902 Answers
Replace the thermostat. The thermostat is shutting down the blower and not shutting down the compressor. Also replace the relay on the compressor as this should be replace when the thermostat is replaced to make sure both are in working order
Posted on Apr 18, 2009
TROUBLE SHOOTING THE Air Condition system
Hi, when it comes to vehicle air conditioning I advise taking it to a
professional with the appropriate experience/qualification...I have heard instances of individuals being blinded by freon.
If your blower only works sometimes might be that the compressor has issues.
Jun 20, 2015 | 1997 GMC Sierra
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
Aircon stops after few minutes without having the room cooled the correct temp.The compressor does not start .We have to wait for a long time after shutdown and restart for it to cool again. If not
Most possible reason in this case is defective compressor(it overheats),or not enough freon in the system. Solution 1.change compressor;2.Recharge the system with freon.
Apr 02, 2014 | Carrier Heating & Cooling
The air condition doesn't blow cool air when it's on. what could it be?
freon leak, check to see if compressor is kickin on, look under hood for a/c compressor. the front will move with the pulley if its working, ... if not working its low on freon or low pressure switch is bad,
Apr 02, 2011 | 1991 Lincoln Town Car
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
Aircon is only blowing ambient air with no cooling effect. the indoor and out door unit appear to be operating normally. am I out of gas or is the compressor not running? what could cause this to suddenly...
First of all check your compressor is working with correct amps. If yes, service your unit to improve better cooling. If compressor not working find out the root cause for it. Please call repairman to find the fault.
We can only give solution by having particular cause or error code is stated by you.
And also follow these tips always:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 16, 2011 | Fujitsu 18C1 Air Conditioner
1996 audi a4 aircon problem
You have a leak most likely, and these are typically hard to spot without test equipment. Take it back to your technician and ask him to recharge the system and perform a dye test to locate the leak. Could be as simple as a bad o-ring in a fitting, or as complicated as a seal in the compressor.
Jan 05, 2010 | 1996 Audi A4
Citi Golf Aircon and Wipers not working.
Check under the dash on the drivers side for two relays,one controls wipers and blower fan,probably corroded.good luck
Aug 17, 2009 | 1998 Volkswagen Golf
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
I have a Mazda mx6 and the aircon won''t work.
what won't work? the interior fan or is all else well except the cooling part? if the compressor does not come on, then perhaps you need to refill gas. in the very front of the car under the hood, you remove the plastic covers where the hood opener is, and you will see some pipes & a canister. on top of this canister there is a clear small round site glass, you can check there for gas if you have dye, or you can unscrew the cap over the refill nipples and depress with you finger nail, air (gas) should blow out under good pressure, not a little only. there is also a fuse you can check situated in the same place, this is for the compressor
Jul 02, 2009 | 1997 Mazda MX-6
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
