Question about Amana ALW480DA Top Load Washer
Extremely loud spin cycle after belt replacement
Using online guides and suggestions, we repaired the broken belt on our Amana top-loading washing machine. Now it washes and agitates fine, but the spin cycle is so loud you have to shout to be heard in the same room . It is a whirring noise, like a jet before take-off. All parts are accounted for... what did we overlook or how do you fix this?  Thank You.
    President:
  • 1,902 Answers
It sounds like the belt is the wrong size meaning that it is to tight or to lose. Check to also make sure that the brake is disengaging and not rubbing on the drum
Posted on Apr 18, 2009
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Washer fills and goes to agitation cylcle, but weak to no agitation. Upon final spin cycle, began making a loud rapid ratcheting sound and did not spin at all. Machine did drain. I did not observe the...
The direct drive coupling between the motor and transmission has stripped out.
It must be replaced.
This video will help in the repair.
http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=player_embedded
Feb 03, 2011 | KitchenAid KAWS750L Top Load Washer
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Leaks water and is abnormally loud during spin cycle
Sounds like the bearings are broken. This is a serious issue and may be quite expensive. If your appliance still under warranty, contact the manufacturer for assistance. If not, don't be afraid to ask the customer service if they can provide some assistance to replace your washer (as the repair will be quite expensive), perhaps the manufacturer may be able to provide a rebate or something like that if they appreciate you as customer.
Good luck.
Aug 31, 2009 | Amana Washing Machines
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana ALW480DA Top Load Washer Logo
374 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
