Question about Samsung SGH-D900 Cellular Phone
Wireless bluetooth headset
I have a bluetooth earpiece (wep 200) that came with my phone. I have paired it with my phone and when i make calls i can hear and speak to the person calling. However, when i recieve calls there semms no way to accept the call via the headset and i cannot hear the person or speak with them through the earpiece.
    Brigadier General:
  • 7,752 Answers
  • press the answer button at the side of the headset
Posted on Jul 04, 2008
How to connect it to samsung seek cell phone
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Mar 31, 2011 | Plantronics Explorer 320 Wireless Headset
When I try to pair my bluetooth to my phone it askes me for a password and i dont know what the password is. I have tried 0000 and every other possible combo i could think of.
Make sure you're trying to do it correctly. Also that you are indeed selecting the correct earbud. While the earpiece is off.. press and hold the 'Call' button for ~10sec.. it should start blinking two colors. After that you have about a minute to go to your phone, turn on bluetooth and search for the earpiece. The passcode should be 0000. If all else fails, clear your Bluetooth list in the phone completely shut it down and pull the battery. Try to turn it on without the battery (this makes sure it has been discharged completely) then replace the battery and boot her back up. Hold the call button on the earpiece until it blinks red and blue.. try to pair them again the the 0000 passcode.
Best of luck.
Mar 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do i pair with an iphone 3g
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 23, 2010 | Samsung S3650 Corby blackwhite + WEP 490...
How do I sync my replacement ear piece
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
Dec 08, 2010 | Plantronics CS70 Wireless Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
Oct 14, 2010 | Plantronics CS70 Wireless Headset
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
Oct 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Pairing Problem with Cell Phone and Bluetooth earpiece
Not all bluetooth headsets are compatible. These are:
BlueAnt Wireless X3 micro Bluetooth Headset.
BlueAnt Wireless V12 LCD Bluetooth Headset.
BlueAnt Wireless Z9 Bluetooth Headset.
http://www.yourwirelesssource.com/buy/accessories/cat/28/model/1005_300368/accessory/291758?source=google_base
Mar 28, 2008 | Cell Phones
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Samsung SGH-D900 Cellular Phone Logo
81 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
