My television keeps cutting off several seconds after I turn it on. All the connections are secure.
  • whitstx Dec 17, 2007
    Mine is the RCA 24v511T 26" RCA. Mine keeps turning on and off. Even manually turning it on and off does not work. When it is plugged in it keeps turning on and off on its own.
  • Awill777 Jul 15, 2008
    My 52 inch Akai keeps cutting off after 15 seconds. Is this a minor or major problem?
For open and off tv
check circuit breaker for over load,,might have lost contact or open resistor connected or check parts
that may have change in its value when supply conected.
Posted on Sep 28, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Can you clarify it
Posted on Sep 18, 2007
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button
if it does not work the first time....try holding down the tv off button a bit longer
Jan 02, 2015 | Panasonic PT-56DLX76 Television
98 prelude starting issues
This is a very common problem on Honda vehicles. The security system is known to fail. Basically when you insert your key, the system checks for certain signal. If the system cannot get the correct signal from the key, it assumes the key is incorrect and goes into SECURITY lockout mode. (prevents hotwiring) This has been happening for a long time. There are ways to bypass this now. Read through this page for info, solutions as well.
http://www.diy-gm-security.com/
Dec 16, 2017 | 1998 Honda Prelude
All the wires are hooked up to my radio correctly but when i crank my car or turn the key back the radio doesn't come on. then when i cut the park lights on the speakers make some kind of flickering noise...
I think you need to check your power wires to your radio. This is a common mistake. There are several power wires to deal with. One wire stays hot to keep the clock and radio presets working. The second is Hot when the key is turned on. The third is hot when you turn on your lights for instrument lighting. If you connected this wire for your power source, You would have this problem you are describing. If it's wired correctly, Check the ground wire to the radio. Hope this helps.
Mar 13, 2010 | 1995 Buick LeSabre
Power cuts out while driving but just for a second,but the car keeps going after that, and on the dash one of the lights blink and it says security.
if your security starts to flash check the battery connections on the body & on the motor loose connection can cause this the car thinks someone is trying to steal it when you disconnect the battery or change the battery you have to make sure that you know the security code / or if it is passive the key to open lock then open the door to reset the code
Mar 03, 2010 | 1999 Chevrolet Blazer
TV turns off after a few moments but come back on again after a few seconds
Remove the lamp and check to see if the connections of the lamp and the lamp driver(ballast) are ok or they look bit burned.Also the lamp should always be replaced first especially if is two years old or more.
Check to see how many times the error indicator flashes.If it flashes 5 times then the lamp driver is probably defective.
common problems are lamp and lamp driver(ballast).
let me know if you need more help.
Good luck.
Sep 19, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Model # WF20L6 symphonic
This particular model has a history of this problem.
This sounds like a safety feature built into the television. It may be trying to protect itself from an unsafe electrical source. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly.
May 28, 2008 | Televison & Video
Sony LCD Projection TV turning OFF!!!
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
