Question about Dryers
I have a Kenmore Elite dryer that blows cold air - it won't heat the air up
  • jtknebel Apr 18, 2009
    Fourbuggz:
    I'm really a novice, so you need to explain things to me like I'm a first grader. An ohm Meter - can I get one from Lowe's? If the heating element is bad, what needs to be done to replace it?
    I think the Model No. is 110.6497230
  • 15,935 Answers
Yes an ohm meter also referred to as a Digital Multi-Meter (DMM) is for checking voltages - ac/dc, continuity, and resistance (ohms)
Be sure to get one that measures resistance AND continuity... you will need it to test the coil and troubleshoot the power coming into the dryer.
Lowes, Ace, Home Depot, ACO, Sears - anywhere you can buy a tool will sell a DMM.
Not all are equal - if you need to - ask for help to make sure you get one that measures resistance in OHMs
Usually when that happens the problem is the high limit sensor... not the element. If the element is bad it will usually have discoloration.
Your problem most likely lies with the thermostat/thermastor.
SEE THIS PAGE for a better explanation of how a thermostat works.
CLICK HERE for a parts blowup of your dryer top and console
CLICK HERE for a parts blowup of your dryer cabinet
CLICK HERE for a parts blowup of your dryer bulkhead (where you will be concerned)
You will find the Thermostat #42 on the last link above and HERE
And the Thermal Cutoff #47 in the same diagram and HERE
Thermal Fuses #59 in the same diagram and HERE
And finally...
the element as # 14 and HERE
Troubleshoot in this order - as they become more expensive as you go down the list :D
Thanks for using FixYa - if you require further clarification of your original question - please use the "continue with this expert" option so we are connected in the future.
Thank You !!
Posted on Apr 18, 2009
  • 126 Answers
It sound like the heating element is bad . if all functions work except heat take apart take ohm meter to heating element if bad it will read 0 .
  • mary allman Apr 18, 2009
    yes you can buy a volt meter at lowes that has ohms on it. what model is your dryer.
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Kenmore front load dryer won't heat and timer broken
The most likely cause is the timer is bad. It turns on and off things as it cyles through and the first step is to get the tub turning before it turns on the heat.
Jun 01, 2012 | Kenmore Dryers
Kenmore Elite HE# electric dryer mod # 110.82822103 - Dryer turns on, but no heat and clothes unable to dry at all. It's like fluffing them with cold air blowing on them. :(
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)Here is a link to a video that will walk you thru the process.Here is a link to any of the parts you may need to fix it.I hope this helps you,Rick
Nov 28, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I have a kenmore elite smartheat quietpak 9 model#110.85872401, it will not heat up just cold air. the air lint filter is clean.
make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Nov 07, 2009 | Kenmore Elite HE4 Electric Dryer
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
