Question about Mmats Juggernaut 15'' Car Subwoofer
Speaker repair I have two Juggernaut 15" speakers. One has the rippled cover below the cone torn lose from around the cone at the center of the rippled cover. The other speaker has one of the wires that connect to the cone of the speaker for the voice coils torn off of the cone close to the cone. Is there any repair kit for this problem, tips, solutions or repair shops around my area of Hickory NC 28602?
Contact MMats Pro Audio at 561-842-0600. They can re-cone it for you, or sell you the re-cone kit. If that does not work for you, contact MWA Speaker Parts in Tuscon - 520-647-7193. They can sell you a re-cone kit, or they can direct you to a speaker repair center near you. A third option would be to contact Sundown Audio in Troutman, NC. They may be able to re-cone it for you.
Posted on May 28, 2009
  • the12voltrep Sep 19, 2011
    A Juggernaut 15 recone is only $230 compared to $799 for a new one...not a bad deal.
I need to get repair kits for my 12' dreadnauts where do I go?
Posted on Apr 26, 2011
Hey, i'm no expert, but i fixed a few speakers b4... there are professionals who can order parts and install for a pretty penny...but why? buy new ones or do what i did, silicone the tears in the cone, and fo the ripped wires, if they are sticking out, you better be real careful and soilder then together and possibly cover them with shrink wrap.. Hey if the speakers are in bad condition, you may as well forget about them and take the magnet off of the basekt and put it on your fridge and tell ppl who come over it's the worlds most expensive refigerator magnet...lol have fun
Posted on May 19, 2009
Fix a torn speaker cone?
If it is a woofer, you would probably fix it quite easy. If the speaker driver is used for both bass and midrange, you have a problem.
Fixing a speaker cone is depending on the material. If it is paper cone, it is very easy by using paper that you glue with wood glue (White water based glue) on to the cones rear side (for estetic reasons).
A midrange or bass/midrange driver is operating in frequencies where the cone starts to break up. Not torn apart, but the break up frequency is the frequency where the inner and outer part of the cone not longer follow each other in the same direction. These properties of a cone determine the sound of the speaker which is that type of speaker drivers "identity". Messing that identity up, you end up with a speaker that does not sound as the original one.
Remember that cross over network used to split up frequency ranges, not only are lowpass, bandpass, and highpass filter, but they also filter irregularities where the speaker driver is not longer providing a linear frequency response (Its characteristic sound).
If the cone is polypropylene, there isn't much glue that bite on that material.
May 02, 2016 | Audio Players & Recorders
Only my left front and back speakers work and they keep cutting out. What can i do?
The speakers or the connections to the speakers are loose. Usually the speaker's paper cone is torn. Check to see where the speakers are mounted. Usually you can hear them or see the cloth grill covers. Most of the time they're in the bottom of the door panel or in the kick panels.The speakers can be checked out by removing the door panels, bottom half at least. If the car is more than 15 yrs old the speakers will have to be replaced. But if the car is newer, it could be in the radio itself. So don't be too quick to remove the door panels.
Hope this helps.
Jan 31, 2015 | Cars & Trucks
Blown speaker
Your best bet here would be to contact one of these authorized dealers for advice I think.
-Steve
Find Service Center
Nov 14, 2013 | Behringer B1520 Pro Eurolive 15" 2-Way...
I can't remove the speakers from my Harman Kardon Go + play, is there a trick to do it?
You can remove the grill in front of the speakers by using 2 mini mini screw driver one to pry it out little by little while the other to hold it from going back in .There are noscrews holding the grill.They are held by 4 clamps which are the grill inner end bend abit out thats all. So if you pry it will give way not to worry the grill is made of a hard aluminium material it just needs care in order not to scratch the paint surface and aluminium ring around it,use a soft cloth to protect the ring when prying.Remember this aluminium ring wont come out its only the grey grill that will. This thing is worth saving because it sounds great even after speaker repair.Yes where i am in Idonesia there are people who are profesionals at repairing speakers that are torn out like our harman.(torn due to age around the speaker cone).i paid 15 usd to get the both of them repaired and its the best 15 dollars i have ever spent.Cause now it could not have sounded any newer the bass is back the balance is pure harman again
Oct 22, 2012 | Harman Kardon Go + Play Portable Speaker...
HOW TO GLUE SPEAKER BACK TO BASKET
It sounds like your speaker surround blew away and separated from the speaker cone and/or housing. I'm in the process of fixing one my speakers by replacing the surround.
Generally, when this happens, you'll want to completely replace the speaker surround (the outer ring that allows the speaker coil and cone to travel in and out, usually made of rubber or foam rubber). This isn't necessarily super difficult, it just takes some time, skill and patience, if you want to avoid messing up the speaker and sound from it.
Inspect and repair your existing speaker:
1) Measure:
a) the diameter of your speaker cone (outer edge of the angled piece that goes inward toward the center coil) and the
b) diameter of the speaker housing (the metal "frame" part the speaker surround glues to, which is usually where the speaker mounting holes are located).
Note
whether the area on the speaker cone where the surround connects to is flat or angled.
2) Ordering: You'll want to purchase the new speaker surround to match the similar material you've already got, as close as possible to the exact dimensions you measured in either flat or angled for mounting to the speaker cone.
SpeakerWorks.com tends to be a bit more expensive than others than can be found online, and they will normally have what you need. Their speaker surround repair kits normally come with instructions, surround, glue and a little brush. I found hunting around can save 50% or more.
3) Gluing: Get yourself some Aleene's Tacky Glue (online or in craft stores), and make sure you don't use too much or too little, applying in a uniform coat on one surface, then applying gentle pressure to get the surfaces to stick, and allow it to dry completely for 24 hours.
IMPORTANT: This can be tricky, so be patient, or you're buying a new speaker. If you don't feel comfortable, take it to be repaired properly.
Typically, you'll want to start gluing the new speaker surround to the outer portion of the speaker cone, either on the underside or inside, as it was with the prior surround. Make sure it's centered, applying just enough glue with a brush to insure it holds and you can still slide everything around slightly into proper position. Gently move the speaker in and out to make sure nothing is rubbing. Allow this to dry for a full 24 hours, and do NOT attempt to glue the surround to the housing until after the cone glue is completely dry.
Now, it's at least 24 hours later, you can do the same thing by applying an even layer of glue to the surround (or onto the frame) to complete the new surround replacement. Apply light pressure to make sure it's centered, again gently moving the speaker in and out to make sure nothing is rubbing. Allow this to dry for 24 hours, just like before.
I know, impatience makes this difficult, but then you don't want to be doing this all over again by trying to move too quickly. Worse yet, you can end up completely destroying your speaker cone.
The nice thing about that tacky glue is is holds well and allows you to position things for a while before it sets. Just remember to allow the proper drying time, which is always way longer than the dry glue you can see.
Remember to defer to a professional repairman if you do not feel comfortable doing these repairs yourself.
I hope this helps!
Feb 16, 2012 | Kicker S15L7 Car Subwoofer
It is rip in to little piecies
It may not be worth the expense, but if the cone or surround are torn, they can be replaced by a speaker repair shop. I just had a pair of JL 10W6's re-edged (the foam surround around the cone deteriorated after 11 years), and the repair cost $100 for the pair, including parts.
Nov 01, 2010 | Thump TBB102 Car Subwoofer
Does mmats sell the rubber surround for a 12 inch procast? one of my procast needs a new rubber. Do i have to sent it in or can i fix it at home/
You can do it yourself if your handy. Lots of places out there selling them. Not too bad a job. Takes some patience gettiog the old one off.. If its really rubber and not foam, it'll come off in one peice. Have to be carefull the get the cone centered when ya glue the new one in. If you decide to tackle it get one with instructions and/or a good web search on the surround replacement.
Apr 06, 2010 | Mmats Juggernaut 15'' Car Subwoofer
I have a juggernaut 18'' and the cone is pushed in is there any way to fix it
find a place that rebuilds subwoofers and send it into them for repair. they will need to replace the spider on the subwoofer.
Jan 29, 2010 | Car Audio & Video
I need the corrects specs for my 15
Heres all the specs you could ever need: http://www.shopping.com/xPO-Mmats-Juggernaut-15
Nov 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Technics speaker torn
most of the older Japanese speakers must be repaired ratther than replaced if the frame is squared or odd sized. many had a flange making a 15" speaker a 16" size or were square framed so that a round replacement will not work. if it is a standard size round frame speaker, then this is easily replaced. if the tear is only on the center dome or dustcap, then this can be easily replaced. if the actual cone is torn or there is other damage to the moving parts, then the speaker can be reconed. often modifications must be made due to the current availability of standard sized parts vs the original metric, etc, but in the end, the reconed speaker will perform as closely as possible to the original and sometimes better.
cathy@speakerex.com
Jun 25, 2009 | Audio Players & Recorders
Mmats Juggernaut 15'' Car Subwoofer Logo
838 people viewed this question
Top Mmats Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tariq Waheed
Tariq Waheed
Level 1 Expert
Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
